FS: D-series parts and other crap
I moved most of my stuff home from the shop and organised and inventoried everything... updated the list.
Just keep checking, I'll add new stuff at the bottom.
If you want to calculate shipping my zip is 12180.
D16A6 head, I was told it's ported. It looks like it sat for a while and could use cleaning or possible rebuild, there's a bit of corrosion and carbon build up. It didn't come with a valve cover, but I'll include a sandblasted 8 valve VC with it. The only difference is that it doesn't say "16 Valve" above "Honda Motor Co."
D series alternator, brand new NAPA reman
4 D series starters
D16A6 clutch from a 90-91, with pressure plate and flywheel, lots of life in it
6 PM6 pistons
3 P28 pistons
all pulleys and sensors out of A6 block
Megan Racing Underdrive pulley for A6
box of motor mounts and brackets
MSD D series 8.5mm "Super Conductor" plug wires
3 water pumps, all in working condition
d16a6 throttle body (no TPS)
B18A throttle body (no TPS)
underhood fuse box
D series timing cover
2 thermostat housings with working thermostats
DX head complete
Si tranny
complete AC wiring harness, uncut including the AC firewall grommet
head bolts (2 sets)
crank pulleys (2)
DPFI dizzy
stock CRX O2 sensor
D15 ACL rod bearings
3 13x8 4x114 aluminium 2-piece wheels, with 5 Hoosier c3000 RR slicks
Civic Si dash
D16Z6/Y8 valve cover (the "H" over "Honda" one)
JDM Playstation2 with some games
2 Si exhaust manifolds
Y8 ignition control module, new
4 good Si injectors (came out of my car) *sold*
red Datum1 tow hook in great shape
Nokia phone datalogging cable
Modified by downest at 4:18 PM 3/30/2007
