How easy is it to blow out the piston rings???
Old Mar 28, 2007 | 08:30 PM
bigsubs's Avatar
Default How easy is it to blow out the piston rings???
I don't have any compression on my #1 cyl. changed the head gasket and same results, I had down shifted and my rpm's was too high before I shifted and didn't know ot and when I did look out. As we speak car will star but will mos def be RICH as hhell. Also the other cyl.s has comp @ 215, 180 ,210 ,0. Input please.
Old Mar 28, 2007 | 09:44 PM
soulpwr's Avatar
Default Re: How easy is it to blow out the piston rings??? (bigsubs)
Hey Shade-Tree, when you changed the gasket, what did the valves look like?
Old Mar 28, 2007 | 10:21 PM
92TypeR's Avatar
FSAE
Default Re: How easy is it to blow out the piston rings??? (soulpwr)
Never heard of "blowing rings".
Cracked ringlands...thats another story.
Sounds like valves to me.
Old Mar 29, 2007 | 02:35 AM
Jay_Sensing's Avatar
Sounds like every other "I misshifted and have no compression" bent valve story to me as well. man.
Next time you take the head off, hit the intake and exhuast ports with some carb cleaner if you can't see the bent valves and I bet #1 will **** fluid right into the combustion chambers.
Old Mar 31, 2007 | 06:58 AM
bigsubs's Avatar
I didn't look @ the valves, never crossed my mind. I don't hear any unusual valvetrain noise and the top of the #1 piston didn't have any marks indicating any contact.
genoaragon869
Feb 28, 2010 09:33 PM
EK_GSR
Oct 23, 2005 06:44 AM
SprayinCX
Aug 12, 2003 03:27 AM
