fuel system drain valve
Old Mar 28, 2007 | 06:49 PM
fast forward driver's Avatar
Default fuel system drain valve
nhra rule book says "all cars must be equipped with drain valve located on return side of fuel rail to facilitate removal of fuel sample -for fuel check....
so my pressure regulator is after the rail, i had planned a line off of regulator where it has provison for a guage. ( with a a/n cap on line -remove this for fuel ck) this is still pressurized ... is this ok?? , or do i need to a T-in the return line after regulator???
Old Mar 28, 2007 | 07:26 PM
vaporboy12's Avatar
Default Re: fuel system drain valve (fast forward driver)
im just going to use the port on the reg for my crap bucket
Old Mar 28, 2007 | 08:49 PM
RPRacing's Avatar
i just went out and bought a petcock and some -6 line today. just gonna put the petcock in the center of the line. i'll get to it whenever.
Old Mar 29, 2007 | 07:05 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: fuel system drain valve (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">im just going to use the port on the reg for my crap bucket </TD></TR></TABLE>
same here.
Old Mar 29, 2007 | 07:13 AM
vaporboy12's Avatar
Default Re: fuel system drain valve (boostedcivicsir)
jegs sells a 1/8 one for like $70
Old Mar 29, 2007 | 07:16 AM
vaporboy12's Avatar
http://www.jegs.com/webapp/wcs...10019
Old Mar 29, 2007 | 07:54 AM
underpressure02's Avatar
I was going to get the aermotive fuel check valve and install it on my fuel rail on the spare 1/8 npt port.
Old Mar 29, 2007 | 04:42 PM
HR-1320's Avatar
Default Re: fuel system drain valve (underpressure02)
Chad the aeromotive check valves are to hold pressure in the line not drain. I'm not sure if they even make drain valves. Just trying to help in case you buy the wrong piece.
Old Mar 29, 2007 | 04:46 PM
GrinderGuy2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.jegs.com/webapp/wcs...10019 </TD></TR></TABLE>
i posted this up about 3 months ago. seems to be one of the only clean and simple solutions.
Old Mar 29, 2007 | 04:51 PM
HR-1320's Avatar
Default Re: fuel system drain valve (GrinderGuy)
I just went looking and aeromtive makes a fuel sample valve that looks much more trick than that jegs one. Its $68 compared to jegs $64.
Old Mar 29, 2007 | 04:53 PM
Default Re: fuel system drain valve (HR-1320)
post it up steve!
Old Mar 29, 2007 | 04:56 PM
HR-1320's Avatar
I wish I was good like that . Go look tho, go to products then fittings and to the bottom. Its sweet. Sorry not a comp guru
Old Mar 29, 2007 | 05:07 PM
this one.............. BOOM
http://www.aeromotiveinc.com/pdetail.php?prod=98
Old Mar 29, 2007 | 06:29 PM
Thanks , i will check these out ... but can what i decribed pass tech??? on pressure side after rail?? will change soon to what yall have suggested ,but dont want to have problem at first race ...
Type-Spaz
Mar 30, 2011 02:12 PM
fishy21
May 12, 2009 01:06 PM
The7thG
Honda Civic (2001 - 2005)
Mar 4, 2007 08:27 AM
NXLude
Nov 27, 2005 08:23 PM
TeamCracka
Apr 28, 2004 06:55 AM
