bolts broke off inside block HELP!!
Old Mar 28, 2007 | 04:55 PM
Homotor's Avatar
Default bolts broke off inside block HELP!!
motor mount bolts broke off inside my block.. does neone have a write up showing the drilling out of the bolt and rethreading it or ne way of fixin my problem?
Old Apr 17, 2007 | 07:11 AM
willseghatch's Avatar
Default Re: bolts broke off inside block HELP!! (Homotor)
i have the same problem, did you ever get it figured out. Cause i need to know how to fix as well. please holla back at me at williamnbailey@yahoo.com thanks i appreciate it
Old Apr 20, 2007 | 02:11 PM
sitinthehall's Avatar
You might be able to tack weld something onto the top of the bolt and get it out that way.
Other than that if you can drill a hole out of the middle of the bolt where you're pretty much drilling out the whole bolt (except for the threads) then just kind of peel the threads out with a tap or small screwdriver or something. Only bad thing about that is you have to worry about centering and drilling perfectly...
I don't know if that's real clear or not...
jhof_wagon
Dec 14, 2012 12:29 PM
jorge59la
Jun 18, 2008 02:57 PM
allmotorb18c14door
Welding / Fabrication
Mar 2, 2007 12:04 PM
93preludes
Dec 4, 2003 01:58 PM
Eggman
Jun 27, 2003 11:06 AM
