MSD 2 step question
I got the whole set up with external coil
I was wondering, what kind of spark plugs do you recommend using with it? and spark plug wires?
I have NGK ones right now and NGK v power plugs
would the spark plug wires be ok? cause they said on the box not to use soild core wires, and Im pretty sure that NGK are magnetic so iunno if thats solid or not
test the resistance. usually solid core wire is only found on a roll of cut-it-yourself nowadays. if there's no resistance, its solid core, if theres so many kohms (i dont remember exactly how many), theyre regular wires.
indy_93accordex
Feb 26, 2004 11:42 AM
