clutch ????
Old Mar 28, 2007 | 02:54 PM
JLefevers's Avatar
Default clutch ????
ok i have searched and also posted in the accord section but nothing so here it goes back to all my ef buddies my friend has a 90 accord and wants his clutch changed but all the clutches i have done have been in 88-91 ef chassies so i was wondering what would be different? is it still a cable tranny? can i still drop the tranny out from the bottom? any info would be great
Old Mar 28, 2007 | 02:59 PM
Slurp56's Avatar
Default Re: clutch ???? (JLefevers)
It's not a cable tranny, its hydro. just unbolt the slave cylinder from the tranny as well as the hardline brackets. Then you can move the slave cylinder out of the way without having to bleed the system when your done. Other than that, yes it's very similar to your EF clutch. The tranny is a bit heavier, so have a friend help you lower it down or if the car is on the ground, use a jack to lower it.
Old Mar 28, 2007 | 03:53 PM
JLefevers's Avatar
Default Re: clutch ???? (Slurp56)
cool thanx
kim_2_da_chee
May 13, 2009 07:57 PM
DC4 ENTHUSIAST
Nov 18, 2008 09:08 AM
Sleepy_Red_hatch
29
Oct 7, 2005 03:03 AM
LittleDevilBmx
Aug 2, 2005 07:28 PM
