clutch drop tranny?
Old Mar 28, 2007 | 02:36 PM
JLefevers's Avatar
Default clutch drop tranny?
ok i searched this i am usual in the EF fourm but i am changin a clutch for a friend and was wondering if changing the 91 accord clutch is gonna be about the same as changing my crx clutch juss wanting to know what i am getting into before anybody says anything i have changed many clutches in a ef chassie juss wondering bout the accord chassie
Old Mar 28, 2007 | 03:03 PM
hondadude's Avatar
Default Re: clutch drop tranny? (JLefevers)
Same basics, but on the accord you'll want to remove the top case part of the shift linkage, trans in neutral, and stuff some rags in there to keep it clean.
You need the extra room for clearance when coming out with the trans.
Also the trans tail mount, has to be slipped off as you lower the trans and slipped back on as it goes up and in.
And there is a bolt going thru the back of the block into the trans that is up high and hard to see.
If you have done a CRX this should be no problem for you.
Old Mar 28, 2007 | 03:55 PM
JLefevers's Avatar
Default Re: clutch drop tranny? (hondadude)
cool thanx for the reply
Roshawn Clark
Apr 25, 2014 09:27 PM
DC4 ENTHUSIAST
Nov 18, 2008 09:08 AM
04accord94civic
May 25, 2005 03:59 AM
eltweedy
Jan 4, 2002 12:22 AM
albert butterbikini
Oct 10, 2001 10:49 PM
