Size Throttle Body from H22 vs. H23
Next weekend I'm swapping my engine from H23 to H22. On the H22 I've got a sensor on the TB and the H23 doesn't have that.
A friend of mine swapped also and he replaced his TB from his H23 on to his H22, so you don't have 2 sensors anymore.
What I like to know is if the size from the H22 TB is bigger then the H23 or are the equal?
If the H22 one is bigger, I will remove the sensor from the H22 TB and using this one instead of my H23.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 »</TD></TR><TR><TD CLASS="quote">62mm
type s is 64 if im not mistaken</TD></TR></TABLE>
Actually the stock size H22/H23 TB is 60mm, and the Type-S is 62mm.
