BLOX TURBO CAMS QUESTION...OPEN THOUGHTS
Old Mar 28, 2007 | 11:50 AM
Urugly's Avatar
Default BLOX TURBO CAMS QUESTION...OPEN THOUGHTS
Does anyone know what these CAMS are equivelant to based on other companies? Are these ok to run with a simple FI setup? Just wanted to see anyone's thoughts or even experiences....
Here are the specs based on what David S. sent John N. at BLOX:
Mike, the specs are (Blox Turbo Cams):
EX: Primary 151 degrees @ .050” .149” Lift
Secondary 204 degrees @ .050” .322” Lift
VTEC 211 degrees @ .050” .322” Lift
IN: Primary 183 degrees @ .050” .205” Lift
Secondary 206 degrees @ .050” .360” Lift
VTEC 212 degrees @ .050” .372” Lift
I'm still a noob on this cam stuff so I don't know what good specs are. Does this maintain stock idle?
Thanks.
Old Mar 28, 2007 | 12:05 PM
boosted92's Avatar
Default Re: BLOX TURBO CAMS QUESTION...OPEN THOUGHTS (Urugly)
Don't run those cams. They're tiny, smaller than the stock VTEC cams, and will cost you power!
Old Mar 28, 2007 | 12:10 PM
Urugly's Avatar
oh man.... am i better off with GSR cams. Currently B16A2 cams...
Old Mar 28, 2007 | 02:22 PM
non-VTEC's Avatar
wow those are small cam specs....i would not run those......exchange them if you can for the stage 1 cam ot run gsr/itr cams.
i just installed blox stage 1 cams and they have a slightly more aggressive vtec cam profile than ITR cams.
Blox Type-A:
intake: 247deg @0.050 lift:.462
exhaust: 239deg @0.050 lift .420
those are the VTEC lobes. the primary and secondary lobes I'm assuming are as close to stock as possible because it idles very smooth.
EGcivic_95
Jan 8, 2012 11:54 PM
boosted hybrid
Aug 22, 2003 04:01 PM
93 VTEC
Jan 24, 2003 07:11 AM
MysteriousGSR
Apr 15, 2002 06:47 PM
28psiBoosted
Mar 14, 2002 05:12 AM
