Neuspeed Sport Springs Vs Progress B-series Springs
Current Setup: 89 CRX Si, B16 swap, JK Motorsports traction bar, Koni Yellows, Neuspeed Race Springs.
Bounces, badly...the car is very dangerous in turns. I'd like to move down to softer springs. A factor to also consider is the added weight up front from the B swap, and the fact that my rear interior is stripped.
I'm looking into getting either:
PROGRESS B-SERIES SPRINGS
Drop: 2.0"
front: 6.4 Kg/mm / 360 Lbs/in
rear: 3.5 Kg/mm / 200 Lbs/in
OR
NEUSPEED SPORT (green)
Drop: 2.0" front
1.8" rear
front: 4.9 Kg/mm / 275 Lbs/in
rear: 4.0 Kg/mm / 225 Lbs/in
Your thoughts please. Anyone have any experience with Progress springs?
Drop: 2.0"
OR
Drop: 2.0" front
1.8" rear
do you notice it bouncing more in the front then in the back?
also excuse my ignorance if this is an obvious thing but don't people usually rave about the koni yellow and ground control?
also, hows the noise level on that JK bar, doesn't it rattle like crazy? i hated mine.
I can't really gauge the difference between the bounce in the front and rear, but the bounce is horrible period. I hate the JK bar, it is loud indeed. It likes to adjust itself while I drive also.
silentbeatz
Suspension & Brakes
May 6, 2005 07:36 AM
