installed jdm cluster, but have small problem.....
Old May 25, 2002 | 06:49 AM
MrSmith's Avatar
Default installed jdm cluster, but have small problem.....
ok i got my jdm sir gauge cluster put it. Everything works fine except for the dimmer. I double checked all the connections everything is plugged in, but the dimmer just doesnt work. it still dims the dash lights but not the cluster. Any ideas?
Old May 25, 2002 | 06:55 AM
hybridkid's Avatar
Default Re: installed jdm cluster, but have small problem..... (MrSmith)
the dimmer just plain doesnt work.
Old May 25, 2002 | 07:06 AM
jdmciviceg's Avatar
New User
I had the same problem with mine. I had to take all the gauges out of the housing and put them into a US version to make everything work. Good luck.
Old May 25, 2002 | 07:38 AM
MrSmith's Avatar
Default Re: installed jdm cluster, but have small problem..... (jdmciviceg)
so there is no dimmer function on the cluster?
well Im not gonna take the entire thing apart just for that so i guess im gonna have to live with it.... thanks for the info.
Old May 25, 2002 | 08:18 AM
jdmciviceg's Avatar
New User
Not sure if yours has a dimmer function. I figure it does, it just has a different plug then the one I took out of my car. Just swap all the gauges to the other housing and it should be fine.
Old May 25, 2002 | 09:14 AM
Mr. Thunderlips's Avatar
This whole process will only take you about 20 minutes...Not that hard.
Old May 25, 2002 | 10:10 AM
Dr.Kimball's Avatar
Default Re: installed jdm cluster, but have small problem..... (ThunderLips)
I ve had 3 different JDM clusters in my EK. The dimmer never worked in any of them. Im too lazy to try to mess with it, and it dosent bug me all that much.
Old May 25, 2002 | 10:45 AM
MrSmith's Avatar
Default Re: installed jdm cluster, but have small problem..... (Dr.Kimball)
hrmm maybe i will take it out and mess with it I have nothing better to do tonight
One more question. the cluster did not come with bulbs, and it has more bulbs for the backround lighting than my stock cluster. Where can i get the little plastic things that hold the bulbs? I need two more of those. I tried pep boys autozone etc they told me i would have to go to the stealership.... Anyone have a couple extra laying around? I dont feel like going to the dealer and paying $5 a pop for them or whatever they would charge.
Old May 25, 2002 | 10:56 AM
jdmciviceg's Avatar
New User
I probably can round a few up if your are not in too much of a hurry. Just e-mail me to remind me.
Old May 25, 2002 | 11:27 AM
MrSmith's Avatar
thanks for the offer! pm-d you, no email at work
Old May 25, 2002 | 11:34 AM
WHATS VTEC's Avatar
just take the wiring form the us cluster and install it in the jdm one, its easy, thats the only way it will work
Old May 25, 2002 | 12:38 PM
JV's Avatar
JV
Who?
Default Re: installed jdm cluster, but have small problem..... (low93ex)
JDM Hondas don't have dimmer switches. Do what everybody else says.........
Old May 25, 2002 | 01:13 PM
airon's Avatar
Default Re: installed jdm cluster, but have small problem..... (JV)
i think only jdm eg-series cluster have no dimmer not positive though
tommy.
12
Aug 29, 2006 05:27 PM
turbo Si
Jul 9, 2006 07:12 PM
Feelseg
Mar 8, 2006 04:56 PM
137
10
Apr 22, 2004 12:58 PM
mr2kqql
12
Sep 4, 2003 01:02 PM
