YAY! :) got the LS started in CRX but 1 problem now :(
Old Mar 28, 2007 | 06:37 AM
-HONDA-'s Avatar
Default YAY! :) got the LS started in CRX but 1 problem now :(
okay so everything went well started right up first try and sounds mean LOL...No downpipe havent put it up yet!,
Well anyways everything was fine until i noticed while the car was jacked up the right(passenger) wheel was spinning in the air which is normal but then i look at the other one and that thing is STUCK and it wont move at all no matter how much pressure i put on it too move it still wont. So i take off the Drivers side wheel too look at it and i'd push the axle back a little from the hub/rivets and it would start spinning just fine???? and then when i put the axle back on all the way in and put the axle nut it gets stuck again? i think that behind the hub or something is grabbing the axle and not letting it spin. axles are out of a 1991 acura integra and motor is a LS.
Please HELP ME
where are the dust plates? before i started putting on the axles i removed these rings from the axles one each.
Old Mar 28, 2007 | 09:45 AM
ChickenH's Avatar
there is a dust ring on some axles just whack it off its like a rubber ring that would be jammed against your inner bearing.
some other problem ive seen is knuckle is bent bearing is now too close to the back of the knuckle. looks like its pressed in too far.i had to make a spacer out of a grade 8 washer.because they didnt have the cash to buy a knuckle and bearing.
dadrought6
Oct 18, 2008 11:19 AM
B20_CRX
Aug 31, 2008 03:57 PM
GeezerGSR
May 29, 2008 06:43 PM
John.
Jul 28, 2006 10:56 AM
civic889802
11
Dec 28, 2005 11:13 PM
