Rear disc brake swap need help!!!!
Old Mar 28, 2007 | 06:27 AM
Josh22999's Avatar
Default Rear disc brake swap need help!!!!
Hey everyone how are you doing...I been searching all over and I can't find any info on the rear disc brake conversion from the integra to 89 civic...I know there is info out there I just can't find it....
well I got the rear brake assembly bolted up and the rod that you can adjust for allignment (the one on the rear brake assembly closest to the front of the car) is to short...we are also doing this on a 91 crx and we are running into the same problem...I am using the arms off of the 91 integra that is what I was told to use I could be wrong...if you need any other info let me know...
Thanks
Old Mar 28, 2007 | 06:38 AM
crx_si-r's Avatar
Default Re: Rear disc brake swap need help!!!! (Josh22999)
u have to use ur original one from ur car, not the teggy ones.
Old Mar 28, 2007 | 07:20 AM
Josh22999's Avatar
Default Re: Rear disc brake swap need help!!!! (crx_si-r)
thats what I was wondering are you a 100% positive...I ordered ones for a integra but I will be able to return them...let me know
thanks
Old Mar 28, 2007 | 07:54 AM
Loserkidwac's Avatar
Yes you need to use the Civic ones...the trailing arms are identical but the control arms and everything else is different...
Old Mar 28, 2007 | 07:58 AM
89efDUSTY's Avatar
Default Re: Rear disc brake swap need help!!!! (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">Yes you need to use the Civic ones...the trailing arms are identical but the control arms and everything else is different...</TD></TR></TABLE> x2 thats all in search...
Old Mar 28, 2007 | 10:30 AM
Josh22999's Avatar
thanks for all the help...I am going to order the ones for the civic.
slo_hatch
Apr 23, 2008 06:08 AM
mnichols
Aug 22, 2006 06:59 PM
NsX_CrX
May 28, 2004 08:21 AM
sekone
11
Jul 26, 2002 11:18 AM
