Timing Belt...
Old Mar 28, 2007 | 04:27 AM
4thgenx42's Avatar
Default Timing Belt...
Im doing a timing belt on my car very soon. Would any of you recommend I get anything else done while im in there?
Old Mar 28, 2007 | 05:55 AM
pdiggitydogg's Avatar
definately water pump, tensioner, tensioner spring, and bolt
Old Mar 28, 2007 | 05:57 AM
GetawayInMoscow's Avatar
Default Re: (pdiggitydogg)
how many miles on your car?
Old Mar 28, 2007 | 07:14 AM
antiricer's Avatar
yea the water pump definitely
Old Mar 28, 2007 | 05:31 PM
4thgenx42's Avatar
Default Re: (GetawayInMoscow)
Right now 101K. Let me know if there is anything else I should be aware of changing. Also Im going turbo by July if it means anything...
Old Mar 28, 2007 | 05:36 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">definately water pump, tensioner, tensioner spring, and bolt</TD></TR></TABLE>
Buy the prostreetonline kit. Thats what I did and am very happy.
Old Mar 28, 2007 | 06:14 PM
Formula's Avatar
Its also a good idea to replace the cam seals, cam plug, and crank seal since your engine has over 85K miles on it.
Old Mar 29, 2007 | 04:29 AM
4thgenx42's Avatar
Default Re: (Formula94)
Would I be better off buying an aftermarket timing belt (i.e. toda, greedy) or is the Honda one good enough to last me another 60k?
Thanks for the help.
Modified by 4thgenx42 at 8:49 AM 3/29/2007
Old Mar 29, 2007 | 11:40 AM
excivicboy96's Avatar
Default Re: (4thgenx42)
thermostat, flush the cooling system, compression test.
Old Mar 29, 2007 | 11:42 AM
Padawan's Avatar
Darth ModerVader
Default Re: (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">Buy the prostreetonline kit. Thats what I did and am very happy. </TD></TR></TABLE>
Good suggestion. It includes essentially everything you need to change, and it's priced well.
OH_1fstgsr
Mar 7, 2007 10:13 AM
G2_Fella
Aug 3, 2006 11:04 PM
alotawatts
Nov 29, 2004 11:30 AM
808State
Apr 8, 2004 11:48 AM
Bunta
Dec 5, 2001 08:56 AM
