88-89 FOGLIGHTS - How Do You Get To The Bulbs? Lights aint workin!
Old Mar 27, 2007 | 05:27 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default 88-89 FOGLIGHTS - How Do You Get To The Bulbs? Lights aint workin!
EDIT: got the thing open, just needed to soak the screws for a second to get it to open, now that Im at the bulb with it out, how exactly does it disconnect? It has a white wire going underneath it, but I cant seem to get the bulb to POP out
Wat size bulb is it?
I picked up a set of square foglights off what I believe is a 88-89 prelude, the square older style anyways, maybe 6X3" foglights
I tested them on a spare battery just touching the power and ground, one light works fine, the other one does nothing
Hoping its the bulb, but I cant seem to figure out how to get at it aside from prying at the front cover
Hope you can help
Old Mar 27, 2007 | 05:33 PM
darkspector2.0's Avatar
I dno't have one off the car so I can't tell you exactly, but I think it was just a few bolts and the front comes off. But you need to solder on a spade connector to the wiring because the replacement bulb will use one but the factory doesn't.
Old Mar 27, 2007 | 05:40 PM
PINKS's Avatar
Default Re: (darkspector2.0)
The bulb seems to have 2 bare prongs on it and the white wire is simple solderred onto the end of one of them.
Is there a specific bulb I should buy?
Old Mar 27, 2007 | 09:26 PM
danny_d19's Avatar
h1 bulb
It has one wire coming off it, peel back the white cover to find the connection
LuckyJDM
Lighting
Jan 7, 2014 06:43 PM
jdmstockeg6
13
Feb 27, 2008 02:26 PM
MartyMarGSR
May 15, 2003 02:10 PM
GSblueRacing
Feb 12, 2003 10:11 AM
Jaisun
Nov 14, 2002 01:19 AM
