How do you remove the gas, brake, and clutch pedal assembly??
Old Mar 27, 2007 | 05:22 PM
Fuster_Cluck's Avatar
Default How do you remove the gas, brake, and clutch pedal assembly?? 92-95!
Car: 95 Vx
I've got the brake booster and clutch slave cylinder off. I would like to remove the 3 pedal assemblies so I can put a nice coat of paint and new grip on them
Plus I want them out when the interior is resprayed
Thanks for any help!!
Old Mar 27, 2007 | 05:28 PM
boostmywankle's Avatar
Default Re: How do you remove the gas, brake, and clutch pedal assembly?? 92-95! (Hybrid93Hatch)
well if u got the brake booster off, there should be a bolt at the top of the brake/gas pedal setup..like up towards the steering column... then theres only one more besides the ones that hold the booster in place...on the firwal..
then for the clutch pedal, there are 2 (which hold the master cyl) and one up by the column also. then there you go, gotta pull the cotter pin from the master cyl.. then they should come right out
TopEndUSA
Feb 22, 2009 04:10 PM
Solscud007
Jan 13, 2006 04:44 PM
AzCivic1.6
Oct 21, 2005 09:48 PM
ams0465
Oct 17, 2004 09:15 PM
sk4sk4
Jan 10, 2003 02:33 PM
