Problems: Engine vibrates like crazy after track
Old May 24, 2002 | 11:39 PM
lePetitePrince's Avatar
Default Problems: Engine vibrates like crazy after track
I was at Mosport internation speedway today, it was awesome running with 911 and other crazy cars. However, during one of the corner, I down shifted from 3rd to 2nd really hard. Afterwards, my car vibrated like crazy.....so I slow down and pull over. I thought I bended the valve springs or something. Went home, did a compression check..is all good.........my friend told me it might be that one of the engine mount is broken/crack?????Therefore sending all the vibraation into the car.....I will bring my car to a mechanic soon, can anyone tell me what is likely to be wrong with my car?????
Old May 24, 2002 | 11:47 PM
uNF$@#!'s Avatar
Default Re: Problems: Engine vibrates like crazy after track (lePetitePrince)
yes, check the motor mounts. most likely one of them may be cracked from heat?
Old May 24, 2002 | 11:52 PM
GokuSSJ4's Avatar
Default Re: Problems: Engine vibrates like crazy after track (00-0187)
check your motor mounts , mine busted the first time i went to the track .
[Modified by Spoon1, 8:53 AM 5/25/2002]
Old May 25, 2002 | 06:42 AM
Default Re: Problems: Engine vibrates like crazy after track (Spoon1)
THanx guys, I hope that is the only problem too.
Old May 25, 2002 | 08:34 AM
Racer-X's Avatar
Well it's either the motor mounts. Because the only thing else it could be is warp disc but thats only with the brakes pressed.
Old May 27, 2002 | 03:00 PM
t's Avatar
t
Default Re: Problems: Engine vibrates like crazy after track (Racer-X)
Check your axles. If you shifted hard, you may have popped the cv joints.
Old May 27, 2002 | 03:36 PM
spoon_ek9's Avatar
Default Re: Problems: Engine vibrates like crazy after track (t)
just woundering, what u guy mean "shift hard"? is that mean downshift without a speed match?
Old Jun 9, 2002 | 12:52 PM
Default Re: Problems: Engine vibrates like crazy after track (spoon_ek9)
yes I did rev match, heel-toe down shift 3rd to 2nd
my mechanics open up the head, check all the valve, they found that one of the cyclinder can't hold compression..so they thought it might have mis-algin, but now, everything is put back together PLUS, new distrubtor cap, new valve adjustment.
I still get a small vibratoin only at 90km/h.....why is that?? PLEASE HELP
[Modified by lePetitePrince, 9:54 PM 6/9/2002]
Old Jun 9, 2002 | 12:55 PM
could it be the tranny???? some ppl said it might be the LSD?? but i never heard anyone having trouble with the stock LSD.....
Old Jun 9, 2002 | 12:58 PM
and also I have checked all the engine mount, they are all good.....
Old Jun 9, 2002 | 01:15 PM
plsss I need help guys ..really....I don't know what to do now, pls.
Old Jun 9, 2002 | 01:34 PM
hooptie157's Avatar
does it shake only when the car is idling, when the clutch is depressed, released, or what?
Old Jun 9, 2002 | 01:45 PM
Default Re: Problems: Engine vibrates like crazy after track (hooptie157)
it only shakes when the car is at 90km/h..once it passed throught the vibrations starts to go away..and it starts at 85km/h..no matter which gear I am in.
Old Jun 9, 2002 | 02:04 PM
Doctor CorteZ's Avatar
I really think its the motor mounts
Old Jun 9, 2002 | 02:06 PM
sackdz's Avatar
If it vibrates at 85-90kph independent of motor rpm, I would say that cancels out any internals of the motor, clutch, and pp. I suppose it could still be inside the tranny, but more likely and wheel bearings.
Double check your motor mounts and check for suspension and bushing damage, maybe a flat spotted tire, warped rotor, bent wheel?
Old Jun 9, 2002 | 02:24 PM
Default Re: Problems: Engine vibrates like crazy after track (sackdz)
now, I was using the mazda Milliena rims, one of them was bend , I found out after that track event. It was bend when I bought because I didn't hit it.
But I change back to my 16inch rims, which is not bend..so bent wheel is out of the list.
my rotors are warped as for now, but I thought wraped rotors only vibrates when I hit the brake? which it shakes like crazy, but I will change them really soon. But can this be a problem when it is jsut crusing at 90km/h??
Now I am just afraid it could be the tranny..but what type of problems could it be?
LSD?? because I can go into each gear smoothly..
Old Jun 9, 2002 | 02:33 PM
sackdz's Avatar
Ok wheel is out of the question, so:
Start from the wheel bearing/rotor, all the way to the countershaft. All these pieces move in direct relation to vehicle speed (85-90kph). Therein lies the problem if it's in your drivetrain. I think that if the rotor was warped bad enough, it could cause vibration, and it's resonant frequency (this goes for all parts upto countershaft) might have been changed and now you can feel a vibration.
However don't forget to look for a damaged or loose suspension piece and joints, a shot bushing, and double check the motor mounts. You didn't get into any mishaps on the track? It's even possible a loosened body panel could resonate/vibrate at that speed causing a vibration.
Old Jun 9, 2002 | 02:37 PM
ok, I guess I will change the rotor, and check wheel bearing, and countershaft as you have suggested. I am sure the rotor is wrapped very bad, but is it possible that I only get the vibration at 90km/h?
I will double check all engine mount
Old Jun 9, 2002 | 02:42 PM
sackdz's Avatar
Ha, it might be a little difficult to check the countershaft, I was just listing it as a remote possibility. I would guess the problem is coming from the rotor, if not a cv joint or hub. Can you feel it coming from a particular area?
Old Jun 9, 2002 | 03:16 PM
it feels like it comes from the center of the car.....but I have no idea where though.
Diversion
Aug 23, 2009 12:15 PM
PrimeElement
Sep 25, 2007 11:46 AM
tomlinson619
May 6, 2006 06:54 AM
LSTEG96
Sep 22, 2003 10:42 PM
Taco Sauce
11
Jun 4, 2002 02:37 PM
