gsr oil in cylinder 2
Old Mar 27, 2007 | 02:35 PM
ziggz501's Avatar
Default gsr oil in cylinder 2
mmk. so i changed my spark plugs today and i noticed a few issues. first of all, my spark plug in cylinder number 2 had a small amount of oil around it's threads. i'm assuming that the rings are busted. also, the spark plugs were very gray on the ends. that means i'm running a little too lean right? anyway... my question is about rebuilding. wondering if i could just buy a set of type r pistons and rods and drop them in. and if so how much and how long would it take. my other option of course would b to just buy the type R long block and ecu and drop that in. i really need my car everyday so i dunno if having it rebuilt is really a choice cuz i don't really know anything about it. i don't want to b without a car for a week or more... i'm assuming more than likely just buying the type r long block is my only option...
Old Mar 27, 2007 | 04:23 PM
ziggz501's Avatar
Default Re: gsr oil in cylinder 2 (ziggz501)
Well.... if nobody has any estimate of what the rebuilds cost and time will b then can someone at least tell me how to keep the engine from running to lean for the time being? I guess ima just go with a long block, but I need to save up some money...
Old Mar 27, 2007 | 04:43 PM
Sam92Teg's Avatar
The oil could just be from the spark plug tube seal, $2. Don't always assume the worst.
Old Mar 27, 2007 | 04:49 PM
1998b18c1's Avatar
Default Re: gsr oil in cylinder 2 (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">The oil could just be from the spark plug tube seal, $2. Don't always assume the worst.</TD></TR></TABLE>
exactly!!!!!try that b4 anything---and what kind of plugs, wires are installed and how old r they 1st.
type r motor 4.5-5 grand for whole motor.
Old Mar 27, 2007 | 05:42 PM
ziggz501's Avatar
Default Re: gsr oil in cylinder 2 (1998b18c1)
Well, the wires are the ones that came with the car, and the plugs were some NGK, I dun member what kinda, I threw them away... but I put in some NGKs that were a step colder just becuz... I just bought the car a month ago and figured I might aswell change the plugs. The car has 155k miles on it, 1995. It was just a small amout of oil around the plugs threads but I'll look into the tube seal. Anyone wanna tell me how to keep from running lean??
Old Mar 27, 2007 | 08:57 PM
92integraVTECgsr's Avatar
its just your spark plugs seals. buy a valve cover gasket kit and replace all the seals. thats all it is. put some new NGK iridium plugs in and you'll be fine. hondas run a little lean anyways so its nothing to worry about.
do a compression test if ur worried about things.
Old Mar 27, 2007 | 09:15 PM
1998b18c1's Avatar
dont just change the plugs, and a step colder, no--switch back to factory rating. if i was u, since u bought it a month ago, do a full tune-up, not half ***. replace: spk plugs/wires, dist cap/rotor, perform a valve adj n replace the valve cover gasket and spk plug tube seals as well. also replace the fuel filter, too. goodluck
Old Mar 28, 2007 | 08:10 AM
Sam92Teg's Avatar
Why use Iridium plugs? I have the NGK coppers ($2 each) which are the OEM recommended plugs, and have never had a problem with them. I swap them out every 50K miles just to be a baller. 303K miles and counting, running like a charm.
Old Mar 28, 2007 | 08:14 AM
ziggz5011's Avatar
they're just platinum plugs... they were $3 a piece... only cold rating of 6. the guy i bought it from did most that that stuff... i did a valve adjustment already. i bought some tube seals yesterday of the net, should get them next week. i suppose i'll replace the rest of the ignition stuff after i pay my credit card bill...
o yeah, and thx for the info/help guys. lot cheaper than buying a new engine, lol
ls19integra95
Mar 16, 2008 05:51 PM
renzema
May 9, 2005 01:36 PM
VtecDA9
Apr 5, 2004 11:17 AM
Downey
Nov 9, 2002 06:34 AM
JSpecwest
Jan 5, 2002 12:42 PM
