Difference between hf and si
Thanks.. My car has had the dash harness replaced but I don't know if the harness is a hf harness or si harness. I read on a different post there was a difference in the igniter wire between these two harnesses, and I want to make sure I get the right one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deadwrong83 »</TD></TR><TR><TD CLASS="quote">Thanks.. My car has had the dash harness replaced but I don't know if the harness is a hf harness or si harness. I read on a different post there was a difference in the igniter wire between these two harnesses, and I want to make sure I get the right one.</TD></TR></TABLE>
look for the vin # on the dash (driver side) or between the door jams or on the T bar under the hood.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX »</TD></TR><TR><TD CLASS="quote">ok easy answer all si's have sunroofs, hf's dont
Exactly, dead give away!
yea right, hook up a HF harness to your SI and Gaurantee no start, theres like 5 diff wires so if you hook either si into hf or vice versas it WILL not start. I had a no spark prob for 2 weeks, turned out this was the problem
I thought they were the same too, but I read this thread https://honda-tech.com/zerothread?id=1913485 and it was telling me differently...
K20AllMotorEF8
Feb 11, 2012 11:38 AM
Boost Junkie 83
16
Apr 2, 2007 06:28 PM
b18cx
10
Jul 15, 2004 01:10 PM
