Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
oil capacity??? Civic Si
Old Mar 27, 2007 | 01:30 PM
huevosrancheros's Avatar
Default oil capacity??? Civic Si
Hey guys, how many quarts does the 06 Civic Si, take??? And no I don't have an owners manual on me , or in my car.
thanks
Old Mar 27, 2007 | 01:31 PM
haby red fg2's Avatar
almost 5.5 qrts with a filter change
Old Mar 27, 2007 | 01:49 PM
FBPSidan's Avatar
Default Re: (haby red fg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haby red fg2 &raquo;</TD></TR><TR><TD CLASS="quote">almost 5.5 qrts with a filter change</TD></TR></TABLE>
your puttin 5.5 in ur car? Thats more than an Odyssey! You might wanna double check ur manual... here is what mine says (go to last page)https://techinfo.honda.com/rja...M.pdf
Old Mar 27, 2007 | 02:00 PM
Default Re: (FBPSidan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FBPSidan &raquo;</TD></TR><TR><TD CLASS="quote"> your puttin 5.5 in ur car? Thats more than an Odyssey! You might wanna double check ur manual... here is what mine says (go to last page)https://techinfo.honda.com/rja...M.pdf</TD></TR></TABLE>
you might want to go relook you link there its page 282
total is 5.8 qrts
Old Mar 27, 2007 | 02:18 PM
FBPSidan's Avatar
Hmmmm seems u need to relook ur link.. both pgs 227 and 313 have the same figure, and that is 4.6 with filter...so what one are you looking at?
Old Mar 27, 2007 | 02:27 PM
page 282 says total capicatie is 5.8 qrts
Old Mar 27, 2007 | 02:42 PM
cnyej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haby red fg2 &raquo;</TD></TR><TR><TD CLASS="quote">page 282 says total capicatie is 5.8 qrts </TD></TR></TABLE>
I havent looked at my book but when Honda does my changes it says 5 quarts.
Old Mar 27, 2007 | 03:34 PM
FBPSidan's Avatar
just looked at pg 282, i think what your lookin at is how much oil the engine holds, obviously you cannot get all the oil out of ur engine when u change the oil, so if you put in 5.5 and u got 1.2 left in the engine..u have a total of 6.7 qt's of oil in ur car... now how many of us know what happens when u have too much oil in ur car? show of hands...
Old Mar 27, 2007 | 03:40 PM
cnyej1's Avatar
now how many of us know what happens when u have too much oil in ur car? show of hands...</TD></TR></TABLE>
Me! Me! Me!
Old Mar 27, 2007 | 04:48 PM
sagron69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FBPSidan &raquo;</TD></TR><TR><TD CLASS="quote"> now how many of us know what happens when u have too much oil in ur car? show of hands...</TD></TR></TABLE>
I do!
And yea the end of that maual says 4.6 with filter.
Old Mar 27, 2007 | 05:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FBPSidan &raquo;</TD></TR><TR><TD CLASS="quote">just looked at pg 282, i think what your lookin at is how much oil the engine holds, obviously you cannot get all the oil out of ur engine when u change the oil, so if you put in 5.5 and u got 1.2 left in the engine..u have a total of 6.7 qt's of oil in ur car... now how many of us know what happens when u have too much oil in ur car? show of hands...</TD></TR></TABLE>
yeah but when you let it sit on a post lift till it doesn't even drip anymore then it does take almost 5.5qrts which is what i ALWAYS do and even when i do it at home i will lower the car back on the ground let it all drip out
Old Mar 27, 2007 | 06:31 PM
norcal450's Avatar
there is still plenty of oil stuck to your crank and every other major part of your motor. it is more dangerous to run a quart high then a quart low regarding oil level. obviously neither is good but i do not recommend putting in 5.5 qts if the oil change reccomend 4.6. if you feel like it put in a fill 5 but leave it at that.
i have let me quad motor (single cylinder, 5 valve 450cc) motor drip for 2-3 days. i put the plug back in for 2-3 days then pulled it again and to my surprise it flowed out before going back to a drip.
my point...follow the 4.6 rule
Old Mar 28, 2007 | 07:21 AM
Default Re: (norcal450)
I called the dealer and they looked it up in the computer and told me 4.4 quarts. I do the same thing and lower the car to get all the oil out, not much came out. I always do this when the engine is warm.
checked out the owners manual pg 227 it says 4.6 including filter<U></U>, damn!!! thats messed up putting 5.5 quarts, wheres the logic????
thanks for your help guys, i need to put a little more.
Modified by huevosrancheros at 10:32 AM 3/28/2007
Old Mar 28, 2007 | 07:25 AM
norcal450's Avatar
Default Re: (huevosrancheros)
go by what the manual says.
if it states 4.4 or whatever then do that. sometimes they have two different #'s. one for an oil change with filter and one with an oil change and NO filter change. i dont have my SI yet so i dont know.
but do not fill it by going off the "oil capacity" # which sounds like 5.5 from above. 4.5 qts and check it after a few miles and cool down to make sure your right at or a hair below the second dot
Old Mar 28, 2007 | 07:27 AM
jonebone's Avatar
Video Game Collector
The answer is 4.6L as stated in the manual and everywhere else. I, however, usually put in 5 quarts when I change the oil because 4.6 still appears as "low" on the dipstick.
Old Mar 28, 2007 | 07:34 AM
the true answer is fill it up till it is in between the 2 dots on the dip stick
it will take what ever it needs to fill it up so anywhere from 4.4 to 5.something
Old Mar 28, 2007 | 07:47 AM
MinesSlower's Avatar
So you decided to change ur mind and join the rest of us with logical thinking?
Old Mar 28, 2007 | 09:06 AM
FBPSidan's Avatar
Default Re: (MinesSlower)
oops didnt realize other guys from work was logged on.. thats me above.
Old Mar 28, 2007 | 10:34 AM
no cause if you read the question the op asked my answer hasn't changed one bit
he asked the capacity and i posted it
Old Mar 28, 2007 | 08:25 PM
FERIOkid's Avatar
<U>4.6 /thread</U>
Modified by FERIOkid at 4:44 PM 3/29/2007
Old Mar 29, 2007 | 08:51 AM
kloscivicsi's Avatar
Default Re: (FERIOkid)
if you think our car requires 5.5 quarts of oil and have to ask a bunch of people to find out it takes 4.6 i dont think you should be changing it. Bring it to the dealer
Old Mar 29, 2007 | 12:33 PM
gus738's Avatar
Default Re: (kloscivicsi)
i always put a lil bit more close to the top but its not the same amount on the 4dr / 2dr is it ?
Old Mar 29, 2007 | 02:16 PM
Hellzcivic's Avatar
Default Re: (gus738)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 &raquo;</TD></TR><TR><TD CLASS="quote">i always put a lil bit more close to the top but its not the same amount on the 4dr / 2dr is it ?</TD></TR></TABLE>
Are asking if a 4 door car with a K20z3 motor has the same capacity as a 2 door car with K20z3 motor? If that is your question then I believe the asnwer is YES. The common factor is the K20z3 motor.
Old Mar 30, 2007 | 05:21 AM
Nsane's Avatar
Last time i checked the Oddysey takes 4.6 Quarts of oil. The same as the Si.
Old Mar 30, 2007 | 06:16 AM
FBPSidan's Avatar
Default Re: (Nsane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nsane &raquo;</TD></TR><TR><TD CLASS="quote">
Last time i checked the Oddysey takes 4.6 Quarts of oil. The same as the Si. </TD></TR></TABLE>
ill be damned...our techs put 5 in the odyssey's, but either way 5.5 is too much for my baby for damn sure
