EK headliner, adhesive? or just screws?
It's held up with all the trim pieces that touch it: A-B-C pillar covers, rear window trim, mirror, sun visors and their clips, Ohshit handle, coat hook/hanger, dome light and then there are two push clips that hold it up........ be prepared to remove a good part of your interior to get it down/out....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emperor9 »</TD></TR><TR><TD CLASS="quote">so is it trim or adhesive that is holding it up? or both?
thanks,</TD></TR></TABLE>
Both. The adhesive makes it sit firm up to the roof. The trim pieces hold the edges.
If your removing the headliiner to do dynamat then you don't need adhesive. the headliner (I meand the cloth and the backing for it) is held up like CarbonizedDX said, by the pillar trim peices and some push clips. You do have to take out pretty much every interior trim peice out because the headliner is the first to go in, which means last out. Since your doing dynamat you should already have the interior trim peices out anyway.
turnsignalandy
11
Feb 23, 2008 06:15 PM
GeorgiaEK
May 14, 2007 12:05 PM
