usdm header and jdm cat back - cat size ?
Old Mar 27, 2007 | 01:06 PM
ITR3189's Avatar
Default usdm header and jdm cat back - cat size ?
Hi,
how long needs the cat to be with a usdm header and a jdm cat back?
I know the the pipe sizes are different, I only need to know about the cat lengths
thanks
Old Mar 28, 2007 | 10:46 AM
ITR3189's Avatar
Default Re: usdm header and jdm cat back - cat size ? (ITR3189)
Ok, other question. Is the jdm b pipe longer than the usdm and if yes, how much ?
Old Mar 28, 2007 | 11:16 AM
Padawan's Avatar
Darth ModerVader
The cat needs to be approximately 13" long.
Old Mar 28, 2007 | 11:28 AM
exies's Avatar
Default Re: usdm header and jdm cat back - cat size ? (Padawan)
Is it also correct that the b-pipes are the same? The reason the jdm cat is shorted is because the jdm header is longer, compared to the us.
Old Mar 28, 2007 | 11:30 AM
Padawan's Avatar
Darth ModerVader
Default Re: usdm header and jdm cat back - cat size ? (exies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exies &raquo;</TD></TR><TR><TD CLASS="quote">Is it also correct that the b-pipes are the same? The reason the jdm cat is shorted is because the jdm header is longer, compared to the us.</TD></TR></TABLE>
No. There is a slight difference in the length of the JDM and USDM exhaust manifolds, but the main difference is in the length of the exhaust B-pipes. The JDM cat is shorter primarily because the JDM B-pipe is longer.
Old Mar 28, 2007 | 11:32 AM
tartje's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote"> The JDM cat is shorter primarily because the JDM B-pipe is longer. </TD></TR></TABLE>
or should that be, the b-pipe is slightly longer because the cat is shorter
Old Mar 28, 2007 | 11:34 AM
Padawan's Avatar
Darth ModerVader
Default Re: usdm header and jdm cat back - cat size ? (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">or should that be, the b-pipe is slightly longer because the cat is shorter </TD></TR></TABLE>
Good point. I should have phrased that differently.
Old Mar 28, 2007 | 11:36 AM
tartje's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Good point. I should have phrased that differently. </TD></TR></TABLE>
you're good dude
Old Mar 28, 2007 | 12:36 PM
exies's Avatar
No. There is a slight difference in the length of the JDM and USDM exhaust manifolds, but the main difference is in the length of the exhaust B-pipes. The JDM cat is shorter primarily because the JDM B-pipe is longer. </TD></TR></TABLE>
I see, so I had it backwards. What is this slight different in the manifolds? An inch or two? Or it doesn't even make a difference because the lengths are so close?
Old Mar 28, 2007 | 12:38 PM
ITR3189's Avatar
Ok so lets sum this up
jdm header + jdm cat back = 12" cat
usdm header + jdm cat back = ~13" cat
usdm header + usdm cat back = 17" cat
jdm header + usdm cat back = ~13" cat ?!
Old Mar 28, 2007 | 12:48 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR3189 &raquo;</TD></TR><TR><TD CLASS="quote">Ok so lets sum this up
usdm header + usdm cat back = <FONT COLOR="blue">~17.5"</FONT> cat
jdm header + usdm cat back = <FONT COLOR="blue">~16.5"</FONT> cat</TD></TR></TABLE>
Fixed for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exies &raquo;</TD></TR><TR><TD CLASS="quote">What is this slight different in the manifolds? An inch or two? Or it doesn't even make a difference because the lengths are so close?</TD></TR></TABLE>
It's around 3/4", which really doesn't make a difference because of the flexibility in the exhaust hangers.
Old Aug 1, 2007 | 09:13 PM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
goood info
ednyboo
Apr 26, 2007 05:10 AM
austrian type-R
Feb 16, 2004 02:39 PM
2k1TypeR0610
Sep 28, 2001 08:16 AM
Toda Party
Sep 13, 2001 07:48 AM
01itr518
Aug 17, 2001 07:59 AM
