head swap
Old Mar 27, 2007 | 12:25 PM
thetomshow's Avatar
Default head swap
is that possible to put a dohc v-tec on my f23 sohc v-tec ... if yes... wich head.. and what the advantage ?? thx all
Old Mar 27, 2007 | 12:33 PM
hondaracer93's Avatar
Default Re: head swap (thetomshow)
Simply put... yes.
Do a search on G23 and it will awnser all of your questions.
Old Mar 27, 2007 | 12:43 PM
thetomshow's Avatar
anyone... more information ??
Old Mar 27, 2007 | 05:11 PM
TouringAccord's Avatar
H-T Order of Merit
look in the Accord FAQ in the Swaps section.
Old Apr 2, 2007 | 08:00 AM
Lubo_25's Avatar
it is possible but like any hybrid it requires work and extra attention to details to make it run mean...the f23 block is a tough block! the girdle speaks for itself...
Old Apr 3, 2007 | 11:57 AM
Tyte-S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thetomshow &raquo;</TD></TR><TR><TD CLASS="quote">is that possible to put a dohc v-tec on my f23 sohc v-tec ... if yes... wich head.. and what the advantage ?? thx all</TD></TR></TABLE> Yes. You can swap on an H22 head onto the f23 block. And if you got an extra 3k to kick out buy a stroker kit to push it to a 2.4L.
Old Apr 3, 2007 | 12:09 PM
Lubo_25's Avatar
Default Re: head swap (f23a4t)
a decent stroker kit will run you that much if not more...and on top of that a custom erl deck plate of some sort to raise the rod/stroke ratio back to the h22a's 1.58/1...i wanted to do a stroker but in the end ill be using a std. 90.7mm h22a crank instead...
Old Apr 3, 2007 | 12:16 PM
thetomshow's Avatar
and is that bolt on ??
Old Apr 3, 2007 | 12:37 PM
Tyte-S's Avatar
Default Re: head swap (Lubo_25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">a decent stroker kit will run you that much if not more...and on top of that a custom erl deck plate of some sort to raise the rod/stroke ratio back to the h22a's 1.58/1...i wanted to do a stroker but in the end ill be using a std. 90.7mm h22a crank instead...</TD></TR></TABLE> Stroker Kit = Mucho $$$$$. In the $3-$4000 Range.
Old Apr 3, 2007 | 02:41 PM
Lubo_25's Avatar
and is what a bolt on...??
OneSloEk9
Aug 18, 2010 01:32 PM
bakerjsp
May 23, 2006 07:39 AM
blueaccord90
Feb 10, 2005 08:13 PM
91exaccord
Jul 3, 2004 06:46 PM
jlteg
May 3, 2003 10:40 AM
