Fuel Help???????????
Alright last night my car died and wouldnt start up again it sounds like it wants to but it wont turn over I just need to know how to check the fuel pump and the throttle sensor if these are even the problem and also how much do each of these run in the bank
Check for fuel, and check for spark, then you know what direction to go. That is unless your starter isn't turning the engine over, which I can't tell, because you say it isn't turning over, but then you say it sounds like it wants to start...
