coilover options in the $900-1100 range
Old Mar 27, 2007 | 08:37 AM
RTW DC2R's Avatar
Default coilover options in the $900-1100 range
They must be in the price range, have to be height and damper adjustable and I dont want to piece together a setup like Koni/GC. I dont need 10000-way adjustability, but dont want to be "stuck" at a certain height or stiffness. If you can mention spring/damper rate options that would be great too.
Right now Im leaning toward the PIC Selects 12f/14k, but before I commit Id like to know what my other options are and your opinions on them. They are going to replace my current worn out stock shocks and H&R Sport springs, and be used on the road course and drag strip. The car is not a daily driver so I am not too concerned with a harsh ride.
EDIT: PICs came in today, heres a pic and some comments. Installed these and a set of traction bars (not pictured). Super nice units, install and adjustment is cake. I wish it had some brake line brackets though.
Wanted to lower the car a bit but think I went just a tad too low. There isnt enough suspension travel with it this low on full soft (bottoms out the bumpstops) so you have to run the harder settings in order not to bottom out, but that makes it a bit rough on some back roads. Ill probably raise it about an inch so I can run softer with no bottoming out.
Modified by I love lamp. at 11:27 PM 3/29/2007
Old Mar 27, 2007 | 08:42 AM
BlueR's Avatar
Default Re: coilover options in the $900-1100 range (I love lamp.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I love lamp. &raquo;</TD></TR><TR><TD CLASS="quote"> The car is not a daily driver so I am not too concerned with a harsh ride. </TD></TR></TABLE>
fyi, high springs rates doesn't always equal a harsh ride...
if the shock is correctly valve, the ride is actually quite comfortable even with the high springs rates
its when you get a cheap undervalved shock that can't handle the spring rates that you get that POS ride
Old Mar 27, 2007 | 08:58 AM
RTW DC2R's Avatar
Default Re: coilover options in the $900-1100 range (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
its when you get a cheap undervalved shock that can't handle the spring rates that you get that POS ride</TD></TR></TABLE>
I know that johnny tran but even with correctly valved dampers and high spring rates I would assume its slightly more "harsh" than stock. Ive never really had a nice set of aftermarket coilovers so I dont have much first hand experience to compare to.
anyway lets see some options! id like to order these TODAY if possible.
Old Mar 27, 2007 | 09:07 AM
GO-FIGHT-KILL's Avatar
-Ground Control coilovers
-Koni Yellow sport shocks (Rears revalved for adjustability)
-Skunk2 camber kits
-Nice sway bars
Equals, a very fun time.
Old Mar 27, 2007 | 09:28 AM
Jon D's Avatar
Default Re: (GO-FIGHT-KILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I love lamp. &raquo;</TD></TR><TR><TD CLASS="quote"> I dont want to piece together a setup like Koni/GC. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">-Ground Control coilovers
start by reading the post before you answer sucka
Old Mar 27, 2007 | 09:38 AM
white rocket's Avatar
I think it would be a crap shoot at that price. There are plenty of options ie: Omni, F2, D2, KSport, AMR, etc, but I have no experience with any of those. Some people like them and others say they are ****. Mostly because the damper isn't valved properly according to the spring rate. However, the AMR thread in the Suspension Sale section said that every one of their sets were valved differently according to the spring rate. It seemed promising. I looked into them last year but a set of Spoon N1's fell into my lap and I wouldn't trade them for any other set up.
This has probably been said before but trying to get a set up that is ideal for drag AND the road course might be a liitle tricky since the demand for each form of driving is different.
I can definitely give a recommendation but it would exceed your desired price range.
Old Mar 27, 2007 | 09:51 AM
walker111's Avatar
Default Re: (white rocket)
I have heard nothing but good things about PIC....
Old Mar 27, 2007 | 10:01 AM
JohnW's Avatar
Right now Im leaning toward the PIC Selects 12f/14k, </TD></TR></TABLE>
You're done right there. No more shopping needed. Order them, be done with it, and be happy.
Simple.
John- who's loves his PIC's and won't used anything else. BTW- I've also run, Teins RA's, Buddy Clubs, Bilsteins and Tokicos... they all sucked when compared to the PIC's.
Old Mar 27, 2007 | 10:04 AM
godnf8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I love lamp. &raquo;</TD></TR><TR><TD CLASS="quote"> Right now Im leaning toward the PIC Selects 12f/14k </TD></TR></TABLE>
Try the 12kF/10kR, I think you'll be happy.
Old Mar 27, 2007 | 10:05 AM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">I think it would be a crap shoot at that price. There are plenty of options ie: Omni, F2, D2, KSport, AMR, etc, but I have no experience with any of those. Some people like them and others say they are ****. Mostly because the damper isn't valved properly according to the spring rate. However, the AMR thread in the Suspension Sale section said that every one of their sets were valved differently according to the spring rate. It seemed promising. I looked into them last year but a set of Spoon N1's fell into my lap and I wouldn't trade them for any other set up.
I can definitely give a recommendation but it would exceed your desired price range.</TD></TR></TABLE>
yes, I realize there is no optimal setup for both street, road course and drag. I am just looking for a happy medium. Anthing is better than what I have now. And I realize my price range is also probably in the middle of the pack, so just looking for different options that are available in that range.
Old Mar 27, 2007 | 10:12 AM
Default Re: (I love lamp.)
Solely based on others opinions, at this point I would go with the PIC's.
Old Mar 27, 2007 | 10:49 AM
chad's Avatar
Moderator
http://www.picperformance.com
running 14k 16k right now...on the race kaa
will be running 10k 12k soon on the street kaa
Old Mar 27, 2007 | 10:57 AM
hooptie157's Avatar
omnipower
Old Mar 27, 2007 | 11:08 AM
EEK's Avatar
EEK
tenzo's ****a
Old Mar 27, 2007 | 11:12 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
For the given price range, I would also suggest PIC.
Old Mar 27, 2007 | 11:14 AM
tartje's Avatar
Default Re: coilover options in the $900-1100 range (EEK)
why are people running harder spring rates on the rear than the front?
Old Mar 27, 2007 | 11:15 AM
walker111's Avatar
Default Re: coilover options in the $900-1100 range (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">why are people running harder spring rates on the rear than the front? </TD></TR></TABLE>
To get more rotation. They wanna be like mustangs and kick the rear out!
Old Mar 27, 2007 | 11:16 AM
i believe it helps the car rotate better. However, it can be dangerous on the street or for an unexperienced driver.
Old Mar 27, 2007 | 11:26 AM
cltitus's Avatar
i would also have to say pics i have heard nothing but good i called and talked to them about getting a set from them really good guys. they know what the hell they are talking about.
Old Mar 27, 2007 | 11:30 AM
RTW DC2R's Avatar
partially for drag, partially for rotation since Im on stock sway bars anyway and no plans to upgrade them.
Old Mar 27, 2007 | 11:31 AM
Type_RS_59's Avatar
Default Re: (cltitus)
I'm also currently researching a coilover setup in this price range and I am definately leaning toward the PICs.
I feel dumb asking this but is PIC pronounced Peak or Pee Eye See?
Old Mar 27, 2007 | 11:37 AM
EEK's Avatar
EEK
is there a group order on the PIC's going on?
Im tired of the Teins 8/7 spring rate is kinda doodoo
Old Mar 27, 2007 | 11:41 AM
1.8L_allmotormilitia's Avatar
koni and the GC is the greatest suspension setup i ever had. Especially with the 22mm itr rear sway bar it will turn beautiful!
Old Mar 27, 2007 | 11:54 AM
tartje's Avatar
Default Re: coilover options in the $900-1100 range (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">To get more rotation. They wanna be like mustangs and kick the rear out! </TD></TR></TABLE>
haha
if i wanna do that i'll dial the stiffness on my shocks on the rear up to full and then lift off in the middle of a corner
thanks for the answers though, i just didn't think people would want such a permanent solution as having the springs like that
Old Mar 27, 2007 | 11:56 AM
RTW DC2R's Avatar
haha
thanks for the answers though, i just didn't think people would want such a permanent solution as having the springs like that </TD></TR></TABLE>
you can still control it with dampening adjustments in the rear as far as I know. the stiffer springs will just make for an overall stiffer ride but you can still control the dampening.
I ordered the PICs I hope you guys dont disappoint me
