inconsistant starting... or not?
Old Mar 26, 2007 | 10:48 PM
92'si's Avatar
Default inconsistant starting... or not?
ive got an issue with my car. i will greatly appriciate any help.
i have a 92 civic si with an ls/vtec... 99 gsr head w/95 gsr dizzy. <93 b18a1 block. 95 gsr tranny. mugen chipped p06. my cam seals are leaking (just throwing that out there), spark plugs, dizzy cap and rotor are new <3000 miles on them. oil level is normal. the spark plugs ngk iridium are kinda white tho (lean or too hot??)
sometimes i will try to start my car and it will kinda just shake then die.
othertimes i will try to start my car and it wont even try to crank.
then sometimes it will crank real slow, but wont turn over.
im going to replace my battery tomarrow (its a duralast not even 6 months old)
just wondering if you guys had any ideas what could be causing this. i was going to swap the starter then ecu on wednesday with a friends to see if it was either of those.
Old Mar 27, 2007 | 09:39 AM
Ghostdog16's Avatar
Default Re: inconsistant starting... or not? (92'si)
Maybe the starter. I had the same problem but with the starter's solenoid. Try finding a junk yard solenoid if you dont wanna just buy a new starter.
Type_R_Lover
Jan 19, 2010 06:19 PM
sLoWrAcEr
Jan 16, 2010 08:38 PM
jdmed3
Jan 21, 2009 06:21 PM
PurEvl
Dec 11, 2005 05:55 PM
angcurdy
Aug 16, 2004 06:44 AM
