TD-44U Distributor Problem
Old Mar 26, 2007 | 10:31 PM
MatrixGSR's Avatar
Default TD-44U Distributor Problem
Well I got engine swap with this distributor and in the process of disassembling everything I accidentally broke one of the spark plug wire connectors off the cap. So I go to my old parts and I found a cap off my 96' GSR that I replaced... problem is it doesn't fit. The top two holes are slightly off by just a hair... (bout an 1/8th of an inch) so my question is, does the OBD1 Dizzy differ from the OBD2 Dizzy, obviously this isn't a stock distributor but so long as it works I'm fine with it. First thing I will say I did was replace the rotor, that thing was so loose on the shaft.
Also do companies make aftermarket ones like the clear blue / red / green ones that will work for my application? I know I've seen them before and at night seeing it sparking is pretty cool...
Old Mar 27, 2007 | 08:23 AM
MatrixGSR's Avatar
Default Re: TD-44U Distributor Problem (MatrixGSR)
Anyone know if the aftermarket distributor differs from a normal one?
Old Apr 3, 2007 | 10:37 PM
MatrixGSR's Avatar
LS cap fits this dizzy for future reference.
Old Apr 4, 2007 | 08:26 AM
jdm_bones's Avatar
44U = Civic Si Vtec OBD2b
DRAGANDB1
Aug 9, 2018 06:19 PM
thenext
17
Sep 19, 2011 04:47 PM
BIGPAPAWACK
10
Aug 23, 2010 11:51 AM
BoombasticSloth
Jun 21, 2008 03:39 PM
ILuvMyJdmDc4
Nov 27, 2007 04:43 AM
