Method for activating the ABS solenoids?
Old Mar 26, 2007 | 10:31 PM
mstewar's Avatar
Default Method for activating the ABS solenoids?
So I've been working through some brake issues with no luck and have seen a few mentions of activating the solenoids on the ABS system one by one to help solve pedal pressure issues, but I haven't been able to locate how it's actually done.
Can anyone tell me how to do it or direct me to a post that has it? I know you can activate the pump even with the car off by jumping the relay, but I am trying to fire each solenoid.
Thanks!
Old Mar 27, 2007 | 06:52 AM
davidnyc's Avatar
Default Re: Method for activating the ABS solenoids? (mstewar)
I had the same issue on my ITR for all of the 2004 racing season. In 2005, finally just took it to a shop and they actually bled the ABS unit. I forgot exactly how he did it, but he said he removed one of the lines and noticed bubbles at the ABS unit. After that, pedal pressure/travel came back to normal.
Before that I actually wet down my street with a hose, and then accelerated and slammed on the brakes to go into ABS. I did this multiple times... my neighbors loved me! That didn't work.
Oh, I remember, I even bought a small battery and was going to run a charge across the ABS unit to activate the solenoid.... couldn't find out where to do that on the ABS unit.
So I recommend doing "some sort of bleeding" with the ABS unit.
Old Mar 27, 2007 | 06:58 AM
walker111's Avatar
Default Re: Method for activating the ABS solenoids? (davidnyc)
I can check the manual when I get home.... I recently bled my accord ABS, very easy but I dont think its the same as the ITR.
Old Mar 27, 2007 | 08:01 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Method for activating the ABS solenoids? (walker111)
All Type R Integras (including 97) have the same 4-channel ABS system as all other 98-01 Integras. 94-97 Non R Integras have a 3 channel ABS with separate reservoir...
The 98+ manual makes no mention of cycling the ABS system even when replacing the entire modulator unit. It sounds like your problem could stem from the bleed sequence. Honda's bleed sequence for Integras with the later 4 channel ABS is as follows:
LF
RF
RR
LR
If you bled the brakes with the common but incorrect sequence of furthest to nearest from the master cylinder, your gonna leave air trapped in the lines somewhere...
Old Mar 27, 2007 | 08:57 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">I had the same issue on my ITR for all of the 2004 racing season. In 2005, finally just took it to a shop and they actually bled the ABS unit. I forgot exactly how he did it, but he said he removed one of the lines and noticed bubbles at the ABS unit. After that, pedal pressure/travel came back to normal.
So I recommend doing "some sort of bleeding" with the ABS unit.</TD></TR></TABLE>
thanks david.. heh.. the conversation you, anton, onyx00 and a few others from a year or two ago is the one where I saw someone talking about being able to activate the solenoids individually (I think it was onyx00 himself)..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">I can check the manual when I get home.... I recently bled my accord ABS, very easy but I dont think its the same as the ITR.</TD></TR></TABLE>
yeah, the ITR ABS is different. I've bled the ABS on a 95 Accord as well and at this point I wish the ITR had something similar (although it's performance is better than the accord's).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">The 98+ manual makes no mention of cycling the ABS system even when replacing the entire modulator unit. It sounds like your problem could stem from the bleed sequence. Honda's bleed sequence for Integras with the later 4 channel ABS is as follows:</TD></TR></TABLE>
Nope. I've consistently bled by the helms. I've also bled in the "wrong" way, just to see if it changed anything. Essentially, I think I've got air in the ABS and it won't come out. I have done the following without being able to get rid of my very soft pedal (I can easily put it to the floor):
Replaced the booster pressure valve thing
Replaced the MC twice
Replaced the front calipers
Rebuilt the rear calipers
Bled 6 big bottles of the SynPower brake fluid using the following methods: Speedbleeders, OEM bleeders both in the Helm's order and the Farthest to closest order, vaccum pump bleed at the bleeder. I also bled the lines at the ABS and the Prop valve.
This is why I was trying to find out if I could activate the ABS solenoids as I saw mentioned, without driving the car (HC race car, very loud, just driving it is more difficult/illegal than a street car).
Old Mar 27, 2007 | 10:12 AM
davidnyc's Avatar
It is definitely something with air in the ABS unit itself. I bled the brakes according to Helms, according to other methods, fully replaced the fluid, replaced the master cylinder, prayed, did everything.... the answer was bubbles in/near the ABS unit.
Old Mar 27, 2007 | 10:23 AM
94eg!'s Avatar
#1 Super Guy
Loved
Well that sucks. I dug all over the brake section of the Helms and I couldn't find anything about manually cycling the ABS system. I completely believe that cycling the ABS could remove air/old-fluid. One of the ABS write-ups on Stoptech.com goes into detail about having to do this certain ABS systems. They make mention of a device that hooks up to the ABS modulator that looks like a Nintendo Gameboy...
Here is their writeup for some general info: http://www.stoptech.com/tech_i...shtml
If nobody can get you the info you need, you might want to go talk to a tech over at Acura...
Old Mar 27, 2007 | 10:59 AM
mstewar's Avatar
Default Re: Method for activating the ABS solenoids? (94eg!)
thanks for the link to that article. I'm going to try the better of the two local dealers shortly and see what they say.
Old Mar 27, 2007 | 11:16 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Good luck Mark!
Old Mar 27, 2007 | 11:18 AM
walker111's Avatar
Default Re: (Wai)
I just talked to my buddy at Honda, said he's never done it, but will do some research and figure it out.
Old Mar 27, 2007 | 11:52 AM
mstewar's Avatar
Default Re: (walker111)
I just talked to a tech at a local dealer and he said they have no special tool to use and that even when installing a new one they just go out and drive it and engage the ABS a bunch of times and then rebleed it.
it would seem like there would be a better way....
Old Mar 27, 2007 | 01:00 PM
Mugen Mike's Avatar
Default Re: (mstewar)
There is definitely a Honda service tool used to cycle the ABS system.
Old Mar 27, 2007 | 01:04 PM
walker111's Avatar
Default Re: (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">There is definitely a Honda service tool used to cycle the ABS system.</TD></TR></TABLE>
I know on some there is a plug under the passenger side seat that you plug a honda tool in and it cycles the abs...
Old Mar 27, 2007 | 01:12 PM
davidnyc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">I just talked to a tech at a local dealer and he said they have no special tool to use and that even when installing a new one they just go out and drive it and engage the ABS a bunch of times and then rebleed it.
it would seem like there would be a better way....</TD></TR></TABLE>
This is the reason why I just wet down my street and engaged ABS multiple times... but this didn't work.
Old Mar 27, 2007 | 01:24 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (davidnyc)
This is the reason why I just wet down my street and engaged ABS multiple times... but this didn't work.</TD></TR></TABLE>
Did you bleed it again afterwards? That is what the Stoptech article says to try...
Old Mar 27, 2007 | 01:29 PM
mstewar's Avatar
anyway you or someone else might be able to find out what it is or where I can get one?
I called the other dealer in my area and their response was "For $110 an hour you can bring it in and we'll start diagnosing". I told them thanks, but no thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">This is the reason why I just wet down my street and engaged ABS multiple times... but this didn't work.</TD></TR></TABLE>
did whoever fixed yours use some sort of tool? who did end upp fixing yours, the guys in AZ?
Old Mar 27, 2007 | 01:40 PM
Mugen Mike's Avatar
I called the other dealer in my area and their response was "For $110 an hour you can bring it in and we'll start diagnosing". I told them thanks, but no thanks.</TD></TR></TABLE>
I'd imagine you can order the tool through Honda, but I've got to imagine it's expensive as hell. King has one, but it isn't working...
I've got to imagine a dealership would have the tool on hand. I'm sure Acura of Brookfield here in Milwaukee would have it, not sure if it's worth the drive for you though...
Old Mar 27, 2007 | 01:44 PM
Comp97GSR's Avatar
Call some auto parts stores Mark. The Autozone by my hizzouse has one that I could borrow.
Old Mar 27, 2007 | 01:56 PM
davidnyc's Avatar
I was actually living in NC at the time (long story) and was getting my car corner weighted and asked the guy to perform other things....he just did a simple thing to get the air out of my ABS unit, nothing special, no special tools. I'll try and dig up my receipt when I get home.
Found the thread:
https://honda-tech.com/zerothread?id=1260277
http://www.krauseandengland.com/Site/Welcome.html =&gt; I went to these guys. I'll send them an email and see if they remember how they did it.
Old Mar 27, 2007 | 02:01 PM
mstewar's Avatar
Default Re: (Comp97GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">Call some auto parts stores Mark. The Autozone by my hizzouse has one that I could borrow.
really? remember the name of the tool so they know what I'm talking about, or did you just say the ABS cycling tool thingy?
Old Mar 27, 2007 | 02:06 PM
Comp97GSR's Avatar
really? remember the name of the tool so they know what I'm talking about, or did you just say the ABS cycling tool thingy? </TD></TR></TABLE>
I just called it an ABS cycling tool.
Old Mar 27, 2007 | 02:20 PM
mstewar's Avatar
I just called it an ABS cycling tool. </TD></TR></TABLE>
Just called a hub store here and they said they had no such tool...
Old Mar 27, 2007 | 02:22 PM
Comp97GSR's Avatar
Just called a hub store here and they said they had no such tool... </TD></TR></TABLE>
Really? Too bad you aren't closer. Do you have an O Reilly's?
Old Mar 27, 2007 | 02:26 PM
mstewar's Avatar
Really? Too bad you aren't closer. Do you have an O Reilly's?</TD></TR></TABLE>
Yep! I'll try them next.. And a different autozone..
edit: autozone lists their tools available for rent on the website, but no ABS/brake tools are listed..?
Old Mar 27, 2007 | 03:50 PM
Comp97GSR's Avatar
Maybe it was Advance auto parts.... I always get them mixed up.
