middle of 2/3 sleeves has .003 clearance... mill it?
Old Mar 26, 2007 | 08:38 PM
Cimburke23's Avatar
Default middle of 2/3 sleeves has .003 clearance... mill it?
well i blew a headgasket, and checked the block and where the number 2 and 3 sleeves meet it has .003 clearance between the sleeve and a straightedge, these are AEBS solid deck sleeves and i am planning to push the engine to 650whp or so, head is at machine shop now getting surfaced back flat, will be using stock thickness .030 headgasket, would just like to know some opinions of this.
Old Mar 26, 2007 | 09:24 PM
mike93eh2's Avatar
run it.. put some hylomar on the headgasket.
Old Mar 26, 2007 | 09:31 PM
Cimburke23's Avatar
Default Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">run it.. put some hylomar on the headgasket.</TD></TR></TABLE>is that like copper spray or?
Old Mar 27, 2007 | 04:44 AM
mike93eh2's Avatar
no
http://www.hylomar.com/
http://www.valco-cp.com/Hylomar.htm
Old Mar 27, 2007 | 04:47 AM
93supercoupe's Avatar
i would think that the stock gasket could compensate for that little of error, but when at 650 its a ball game ive never been to.
PrecisionH23a's Avatar
Default Re: middle of 2/3 sleeves has .003 clearance... mill it? (Cimburke23)
I assume you are using a TRUE straight-edge? If so, I would have a machine shop deck the block. Also, make sure they sleeves are not step-decked.
Old Mar 27, 2007 | 08:30 AM
Golden Eagle's Avatar
Default Re: middle of 2/3 sleeves has .003 clearance... mill it? (PrecisionH23a)
you should contact aebs and tell them the problem you are having before you go and deck the block, because you might mess it up more then it already is,most of the time decking it will not help, also there is nothing wrong with step decking, we do a .003 step deck on all our blocks no problems with it ever
Old Mar 27, 2007 | 09:01 AM
Default Re: middle of 2/3 sleeves has .003 clearance... mill it? (Golden Eagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">also there is nothing wrong with step decking, we do a .003 step deck on all our blocks no problems with it ever </TD></TR></TABLE>
Correct. I was saying the block could be step decked and this is where the .003" is coming from.
Old Mar 27, 2007 | 10:00 AM
Cimburke23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">I assume you are using a TRUE straight-edge? If so, I would have a machine shop deck the block. Also, make sure they sleeves are not step-decked.</TD></TR></TABLE>yes, it is an 1/8" thick 2ft piece of steel that has been to the machine shop and machined flat . step-decking would put the outside off some also wouldnt it though?
Old Mar 27, 2007 | 10:09 AM
It would be .003" all the way around the sleeve minus where the sleeves touch.
Old Mar 27, 2007 | 10:11 AM
Cimburke23's Avatar
should i post a pic of where exactly i am talking about? with the feeler gauge under it?
Old Mar 27, 2007 | 10:12 AM
but they all arent .003 high, sounds like its just one.
Old Mar 27, 2007 | 10:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cimburke23 &raquo;</TD></TR><TR><TD CLASS="quote">should i post a pic of where exactly i am talking about? with the feeler gauge under it? </TD></TR></TABLE>
I completely know what you are talking about... I was responding to Golden Eagles post. So in order to fix your problem, yes, you will have to mill the surface. I've had a warped water jacket on one of my blocks years ago and I had to do the same. As GE said, contact aebs just in case.
Old Mar 27, 2007 | 10:30 AM
92LSVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">you should contact aebs and tell them the problem you are having before you go and deck the block, because you might mess it up more then it already is,most of the time decking it will not help, also there is nothing wrong with step decking, we do a .003 step deck on all our blocks no problems with it ever </TD></TR></TABLE>
id do exactly what GE said
Old Mar 27, 2007 | 11:02 AM
Cimburke23's Avatar
Default Re: middle of 2/3 sleeves has .003 clearance... mill it? (92LSVTEC)
ok well i went back out and took some pix anyway, in both of these pix it will only fit exactly where it is:
now when i put it this way, it fits where every sleeve meets:
but if i put it at the front or back of each sleeve where the deck is solid it is flat, cant even fit a .0015 feeler in it
Old Mar 27, 2007 | 11:24 AM
SD_Lurker's Avatar
HT White Ops
My friend use to work at AEBS and to be honest with you he told me that I should never use their products.Back in the day there were alot of good employees but since then he said they are no longer there and the place sucks. I am local and would never buy any of there crap. This is the second time in 2 weeks I have heard something wrong with the block. He also told me that they don't even sleeve the blocks then send it to a local mchine shop.
here is the link https://honda-tech.com/zerothread?id=1918238
Old Mar 27, 2007 | 11:38 AM
eh3 93's Avatar
Default Re: middle of 2/3 sleeves has .003 clearance... mill it? (SD_Lurker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker &raquo;</TD></TR><TR><TD CLASS="quote">My friend use to work at AEBS and to be honest with you he told me that I should never use their products.Back in the day there were alot of good employees but since then he said they are no longer there and the place sucks. I am local and would never buy any of there crap. This is the second time in 2 weeks I have heard something wrong with the block. He also told me that they don't even sleeve the blocks then send it to a local mchine shop.
here is the link https://honda-tech.com/zerothread?id=1918238</TD></TR></TABLE>
You're right. This machine shop in Lakeside called Accurate machine does there sleeving. They even did mine but I didnt go through AEBS. I went directly to the machine shop. I have yet to run to motor but hopefully everything works out OK.
Old Mar 27, 2007 | 12:45 PM
yeah i would defiantly call aebs, if they wont do anything for you then i would have the block decked and with there blocks i would have to agree with PrecisionH23a don't do a step-deck do a flat-deck because the way there sleeves are made i think a flat-deck would be best
Old Mar 27, 2007 | 03:48 PM
zexxbo's Avatar
Default Re: middle of 2/3 sleeves has .003 clearance... mill it? (eh3 93)
i went through the guy that does their sleeving for them directly and he offered to warranty the labor regardless of whether or not AEBS will.
Old Mar 27, 2007 | 04:19 PM
BOOSTEd2's Avatar
Default Re: middle of 2/3 sleeves has .003 clearance... mill it? (zeimbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote">i went through the guy that does their sleeving for them directly and he offered to warranty the labor regardless of whether or not AEBS will.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote">i went through the guy that does their sleeving for them directly and he offered to warranty the labor regardless of whether or not AEBS will.
You talked talked to Mylan at Accurate machine right?
Old Mar 27, 2007 | 04:44 PM
JDogg's Avatar
Default Re: middle of 2/3 sleeves has .003 clearance... mill it? (BOOSTEd2)
all my aebs sleeved blocks have been done by z10 and we havent had any problems.
we had some ERL sleeves sink and they insisted that we send the block back to have it resleeved instead of just decking it.
Old Mar 27, 2007 | 06:52 PM
Cimburke23's Avatar
Default Re: middle of 2/3 sleeves has .003 clearance... mill it? (JDogg)
ok well its all apart and in the back of my car now, is there any special way it needs to be done or anything?
Old Mar 27, 2007 | 07:58 PM
zexxbo's Avatar
you have a 10 second car and youre asking if theres a special way to mill your block? you should call aebs before you do anything, they might even fix it for you..
Old Mar 27, 2007 | 08:24 PM
mike93eh2's Avatar
i wouldnt of worried about it. make sure the head is flat throw some hylomar on it and a oem gasket.
Old Mar 27, 2007 | 08:30 PM
Cimburke23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote">you have a 10 second car and youre asking if theres a special way to mill your block? you should call aebs before you do anything, they might even fix it for you..</TD></TR></TABLE>hmm yea i am. just cuz i can drive and build the car right doesnt mean i know everything, i dont work for AEBS or anything you ******* jackass
