Are all B-series transmissions compatable with LS engines?
Old Mar 26, 2007 | 08:07 PM
admess188's Avatar
Default Are all B-series transmissions compatable with LS engines?
I have an LS Engine and went to put my GSR transmission on and it all mounted up and was perfect until i went to put my halfshaft axle on... it went into the transmission good and then went to put the bolts in but the mount was not flush so the 3 holes on the halfshaft axle were sitting out and inch or so... the question i have is are there more then one b-series halfshaft axles? i neeed HELP!!!!!!!!! please
Old Mar 26, 2007 | 08:33 PM
civicstar's Avatar
Default Re: Are all B-series transmissions compatable with LS engines? (admess188)
theres two types, female and male, one is from the cable and one is from the hydro years, they both should fit either way, try turning the half shaft alittle bit and tapping it in with a heavy hammer
ferio_boy
Sep 21, 2009 12:17 PM
integrawow
Apr 26, 2007 08:41 AM
admess188
Mar 27, 2007 12:30 AM
SLOENUF
May 6, 2006 05:35 AM
S2KP
Jun 3, 2004 04:00 AM
