1991 CRX SI $9200 OBO
Old Mar 26, 2007 | 07:39 PM
slow91crx's Avatar
Default 1991 CRX SI $8100 OBO NEW PRICE
1991 CRX SI
121,000 origional miles
3,000 miles on drivetrain
Powertrain:
B18C1 Block - PR3 pistons ( .010 over )
B16A head - dual valve springs , CTR cams.
11.5:1 Compression ratio
178 Hp
130 Tq
( dyno tuned by Tony the tuner in Springfield , Mo. - dynograph available upon request )
PR3 ECU
Hondata Stage 2
OBD0
Hasport mounts
Hasport linkage
Odyssey battery ( little bitty one , BRAND NEW )
Custom battery tray - low to the ground in the front of the car )
- ALL BRAND NEW - OEM HONDA
Bearings
gaskets - EVERY SINGLE GASKET ON THE ENGINE
seals - EVERY SINGLE SEAL ON THE ENGINE
distributor
starter
oil pump ( type R )
water pump
oil pickup tube
windage tray
Skunk2 intake manifold
BBK 70mm throttle body
STR fuel rail
Holley fuel pressure regulator
AEM ITR intake ( 3 inch )
skunk2 cam gears
JDM ITR header ( 2 and 1/2 inch collector )
Custom side exit exhaust w/16" under car muffler
GSR YS1 Transmission ( same gears as ITR transmission )
OBX helical LSD
ACT 6 puck clutch
ACT flywheel
ACT extreme pressure plate
raxle axles
- BRAND NEW - OEM HONDA
GEARSETS AND SYNCHRO's
pilot bearing
throwout bearing
Suspension:
-BRAND NEW-
MOOG BALLJOINTS ( upper and lower )
MOOG tie rod ends
wheel bearings
Ground control coil overs w/eibach springs ( custom spring rates 580 front 740 rear )
KYB AGX adjustable struts
suspension techniques sway bars ( front and rear )
neuspeed strut bars ( front and rear )
neuspeed rear lower tie bar
Full-race front cross member
eurethane bushings
front and rear camber kits
Brakes:
Prelude master cylinder 7/8
brembo rotors
green stuff pads
goodridge steel braided lines
Body:
TOTALLY RUST FREE
EDM spoiler ( wiper hole delete )
VIS JDM carbon fiber hood ( looks just like JDM front hood )
JDM sidemarkers
JDM corner lights
3rd gen prelude pearl white W/ gloss black trim ( painted 4 years ago )
Interior:
MOMO steering wheel
autometer shift light
VERY CLEAN, black/grey
EVERYTHING intact and in great shape , even the rear cargo cover!
the only flaw is a small tear in the drivers side seat , easily fixable.
power sunroof works great, no leaks.
Wheels:
91 crx Si wheels
re-painted in factory finish
no curbs , very clean
Falken Azenis tires - 3000 miles -
Old school JDM GAB wheels: look just like circuit 8's , but with more lip and lighter. ( wheels are stripped , ready for paint . lip is polished )
wheels are stamped enkie and i researched and found that they are early 90's GAB sports. no tires . 15's
Everything on the car has 3000 miles on it pretty much.
All the work done to the engine and transmission was done professionally and i have recepits for all the parts and labor.
no corners cut.
nothing overlooked
this car is very well put together and very solid.
idles perfectly.
starts right up.
runs without a hitch.
I drove the car back and forth from sedalia to lee's summit for work 5 days a week ( 129 mile round trip ) for about a month ( october ). it ran perfectly, actually rides pretty nice for being so low and such stiff spring rates.
I drove the car for a year ( 2005 ) with a b16 in it and then took it all apart for a year and a half and re did EVERYTHING on the car exactly how i wanted it.
Now its time to sell it. lol
i want a stock virgin crx . this is way too much money for me to have invested in a car that i just want to tinkner with ocassionally.
someone will put it to much better use than i do, its not doing anyone any good setting in the garage every day.
PICS:
* car no longer has MSD ignition box. it was ugly and i gained 3 WHP when i took it off !
* send e-mails to dustin@wkchevy.com
if you don't like the price then make an offer. thats what the e-mail addy is for.
$8100 OBO
Modified by slow91crx at 6:59 AM 3/27/2007
Old Mar 26, 2007 | 08:57 PM
junkyard racer's Avatar
I dont want to sound like an *** but, I hope the price for a CRX in indiana with a B series motor and some suspension doesnt normally cost $9200. I'll be back that way in a few months trying to get a car, hope this isnt the cost of them.
Old Mar 26, 2007 | 09:00 PM
HYPROPULSION_R's Avatar
Default Re: 1991 CRX SI $9200 OBO (slow91crx)
$9200??? uh, yeah good luck with the sale. I hope you find a complete retard to pay this much.
Old Mar 26, 2007 | 09:15 PM
civicboisi's Avatar
Default Re: 1991 CRX SI $9200 OBO (HYPROPULSION_R)
i thought it was on a special episode from Pimp my ride to be that much... Bump i guess
Old Mar 26, 2007 | 09:23 PM
slow91crx's Avatar
Default Re: 1991 CRX SI $9200 OBO (civicboisi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junkyard racer &raquo;</TD></TR><TR><TD CLASS="quote">I dont want to sound like an *** but, I hope the price for a CRX in indiana with a B series motor and some suspension doesnt normally cost $9200. I'll be back that way in a few months trying to get a car, hope this isnt the cost of them. </TD></TR></TABLE>
build your own for less..
do the math bud..
rust free 91 si $3000 ( good luck finding one )
paint $1500
itr full swap $4000
suspension and misc $3000
get a clue..
plus its OBO...
this car is practically brand new.. there isn't a wear item on it that has more than 3000 miles on it..
Old Mar 26, 2007 | 09:54 PM
weak_tec's Avatar
i see a rust spot
just kidding dude, very clean gl on the sale
Old Mar 26, 2007 | 10:25 PM
Tyounin608's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYPROPULSION_R &raquo;</TD></TR><TR><TD CLASS="quote">$9200??? uh, yeah good luck with the sale. I hope you find a complete retard to pay this much.</TD></TR></TABLE>
I don't think he understands that this is dialed in better than a rolex
bump for a sweet rex
Old Mar 27, 2007 | 03:21 AM
playalistic2's Avatar
lol 9200? watta joke
Old Mar 27, 2007 | 03:34 AM
I didn't knock the car one bit. Im just sayin, I hope cars like this dont cost dam near $10,000 on a normal basis. Very clean car, but your nuts on the price.
For that much, you could spend that much money and get a no bullshit built motor and a clean car from so-cal shipped to the corn feilds. Thats all im sayin. Your motor is mostly stock and the suspension is nicely done, and you have some wheels. You said that the car is rust free...yet also has fresh paint. Probably rust under the paint...just my opinion.
Good luck. I'll give ya $5000 for it this summer when im home for a month.
Old Mar 27, 2007 | 04:19 AM
7808's Avatar
what u talkin bout? $2900 is a good deal
Old Mar 27, 2007 | 04:32 AM
daoshao's Avatar
Damn....i could do so much with 9200 bucks. Good Luck on sale.
Old Mar 27, 2007 | 06:04 AM
slow91crx's Avatar
Default Re: (junkyard racer)
the paint isn't that freash.. 4 years ago??? if there were rust under it it would have come back through already.. its a 16 year old car.. it needed a re spray. lol
and it is by no means a stock motor man.. thats retarded.. it was very expensive to build this setup and it runs STRONG..
its built with all the best OEM parts out there.. 11.5:1 Cr. ??? NOT stock
178 WHP and 130TQ??? not stock..
what about my car is stock?? honestly??
its got a built transmission too man!!!
i spend $1800 on that transmission alone!!
new price BTW.
Old Mar 27, 2007 | 07:15 AM
715civic's Avatar
Default Re: 1991 CRX SI $8100 OBO NEW PRICE (slow91crx)
bump because i look
Old Mar 27, 2007 | 07:16 AM
Spoolinator's Avatar
Or I could buy 400 Chubby ****** and shove them in between my Cheeks....
Old Mar 27, 2007 | 07:30 AM
RapeV-8's Avatar
sorry but i think $9000 is alot of money also.
but good luck on the sale buddy
Old Mar 27, 2007 | 09:37 AM
slow91crx's Avatar
Default Re: (igotcrx)
new price.
$8100.
have a standing offer for $8000 locally .
Old Mar 27, 2007 | 09:54 AM
SLIPSTICK TIPPIN's Avatar
Default Re: (slow91crx)
nice car but take the 8k and run
Old Mar 27, 2007 | 10:18 AM
Eugene87's Avatar
nice car but i would sale my 99 si for $8,000. $9,200 is a lot! good luck
Old Mar 28, 2007 | 07:42 AM
slow91crx's Avatar
Default Re: 1991 CRX SI $8100 OBO NEW PRICE (NA EM1)
bump , new price!
********8100********
very interested in trades + cash
Old Mar 28, 2007 | 08:30 AM
98tegLSvtec's Avatar
dude you need to put some rims on that car a.s.a.p.....
Old Mar 28, 2007 | 08:52 AM
ProJectCvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crx &raquo;</TD></TR><TR><TD CLASS="quote">new price.
$8100.
have a standing offer for $8000 locally .</TD></TR></TABLE>
Quick!!! sell it to the dude for 8k before he changes his mind!!!
Old Mar 28, 2007 | 09:55 AM
slow91crx's Avatar
Default Re: (ProJectCvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98tegLSvtec &raquo;</TD></TR><TR><TD CLASS="quote">dude you need to put some rims on that car a.s.a.p.....</TD></TR></TABLE>
i have the GAB ( i guess ) wheels setting in my basement.. im just so in love with the re-finished stock SI wheels i didn't even wanna bother buying tires for the GAB's. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic &raquo;</TD></TR><TR><TD CLASS="quote">Quick!!! sell it to the dude for 8k before he changes his mind!!!</TD></TR></TABLE>
and he has to sell his DA first.. or it would already be gone lol
i just wanted to make it fair to anyone else and let them all know his offer, if all else fails i will just take his 5k cash and his DA and sell it myself. lol ( b16 DA can't be THAT hard to sell!! )
but i am getting some really good trade offers right now so keep em commin!!!!
Old Mar 28, 2007 | 10:09 AM
Got Utensils's Avatar
...but i am getting some really good trade offers right now so keep em commin!!!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crx &raquo;</TD></TR><TR><TD CLASS="quote">bump , new price!
very interested in trades + cash</TD></TR></TABLE>
haha..quit lying to us....we all know that you wont get more than 5 grand for your car..
Old Mar 28, 2007 | 11:50 AM
slow91crx's Avatar
Default Re: (Got Utensils)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got Utensils &raquo;</TD></TR><TR><TD CLASS="quote">haha..quit lying to us....we all know that you wont get more than 5 grand for your car..</TD></TR></TABLE>
ha ha i'll keep the car, sell my motor and tranny separate, stick the b16 i have layin in the corner of my shop in the car, and THEN sell the car for $5500!!!
but it won't come to that. so im not worried
Old Mar 28, 2007 | 12:18 PM
BJOnewiper's Avatar
You have a standing offer for 8k but you're holding out on the internet for 8100 obo.
You're a liar.
