b16a cam caps torque specs?
okay today i put in some gs-r camshafts into my jdm b16. so i was wondering if any1 knew the torque specs for the screws that hold the caps or whatever they're referred to called? it the things that cover the camshafts.
The 12mm heads (8mm size) bolts are 20lbs and the 10mm head (6mm size) are 7lbs. What i normally do is just go in order and seat all the bolts. Then go one over to make sure none are loose. It doesnt take alot to keep them down. And your right there called cam caps.
m00nr0ck Si
Jan 1, 2006 12:39 PM
