VSS wtf! i have no clue what to do now!
Old Mar 26, 2007 | 05:50 PM
civiclxb16a's Avatar
Default VSS wtf! i have no clue what to do now!
well along with everything that has gone wrong with my civic this week i went to get my wheel alignment and of course i need a new tie rod, so i was on my way home and my speedo was jumping around like crazy then it just turned off. about 1 minute later my CEL turns on. i get home and i say maybe my vss went bad. i pulled out one of the extra ones i had laying around and i put it in took it for a test run same thing. tried the thrid one same thing, my buddy came over and we took his out and put it in mine same thing. so what we did was pulled out the sensor and spun it by hand nothing. so we started playing around with the plug while spinning the sensor and the speedo would jump once in a while. could it be my plug went bad on me?
Old Mar 26, 2007 | 05:57 PM
95jeremie's Avatar
Default Re: VSS wtf! i have no clue what to do now! (civiclxb16a)
damn man i know the feeling
i drove for like 3 months without a speedo
i replaced the VSS and even the cluster
well ya it turned out the connection went bad
go to a local junk yard and grab up another connection plug
make sure that you have enough wire on it
cut the old one off and solder the new one on
should take care of the problem
Old Mar 26, 2007 | 06:00 PM
Default Re: VSS wtf! i have no clue what to do now! (95jeremie)
is this something common?
Old Mar 26, 2007 | 07:33 PM
T Rick's Avatar
yes mine is doing the same thing but i dont know where the vss is?
Old Mar 27, 2007 | 06:04 AM
Default Re: VSS wtf! i have no clue what to do now! (T Rick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T Rick &raquo;</TD></TR><TR><TD CLASS="quote">yes mine is doing the same thing but i dont know where the vss is?</TD></TR></TABLE> ok if you look at your motor from the passenger side you will see your intake take it off (just easier) and you will see a three bolted down plug on the back of the tranny! DO NOT TAKE ALL THREE OUT! the one that is the lowest mounted 10mm bolt is the one that you take out and the whole sensor will come out. the reason why i say don't take all three out is because of you take the two that hold the sensor down out and you remove the sensor there is a little key in there that spins the sensor if you lose that your done for! let me know if you need any other help
Old Mar 27, 2007 | 09:40 AM
T Rick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiclxb16a &raquo;</TD></TR><TR><TD CLASS="quote"> ok if you look at your motor from the passenger side you will see your intake take it off (just easier) and you will see a three bolted down plug on the back of the tranny! DO NOT TAKE ALL THREE OUT! the one that is the lowest mounted 10mm bolt is the one that you take out and the whole sensor will come out. the reason why i say don't take all three out is because of you take the two that hold the sensor down out and you remove the sensor there is a little key in there that spins the sensor if you lose that your done for! let me know if you need any other help</TD></TR></TABLE>
Thanx
Old Apr 9, 2007 | 11:51 AM
ok it ended up being my clip! i changed it over to a new one and i took it for a spin and BOOM it worked! thanks guys
Old Apr 9, 2007 | 12:00 PM
96 EJ8's Avatar
nice! good to see it worked, I'm having the same problem. now i know what to look for. thanks
Old Apr 9, 2007 | 04:35 PM
Default Re: VSS wtf! i have no clue what to do now! (integra DA9)
no problem man let me know if you get it working!
Old Apr 9, 2007 | 06:57 PM
Jonknee's Avatar
mines fluctuating from 0-20 once in a while and its dead most of the time, it doesnt work at all, i get no vss code till 20 min later after driving, i replaced it twice already, im hoping its not the cluster. im going to change my plug like you.
Old Apr 9, 2007 | 09:00 PM
jdmfrog's Avatar
did you reset your car ecu after replacing the vss? if no? do it...
Old Apr 10, 2007 | 05:46 AM
Default Re: (jdmfrog)
nope i didn't do it why should i the code is gone?
Old Apr 10, 2007 | 06:21 AM
93CX's Avatar
Default Re: (civiclxb16a)
I've had VSS issues for as long as I can remember. I've replaced my sensor 4 times, the plug clip 2 times, and my speedo 2 times. We've determined that there is a short in my VSS wiring in the harness somewhere. Try running the signal wire directly from the plug clip to the ECU and see if that fixes anything.
Old Apr 10, 2007 | 06:29 AM
Default Re: (93CX)
i thought the same thing but i changed my clip and it worked fine, do you have a cel for your vss?
Old Apr 10, 2007 | 08:01 AM
Jonknee's Avatar
after u reset ur ecu, do u get the code like after hard driving.? I dont get the code till like 1/2 hour after driving.
anyway, can anyone post a picture of their plug and which wire is which, my plug isnt the right one and i cant find a picture of a pinout.
Old Apr 10, 2007 | 08:13 PM
Default Re: (Jonknee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonknee &raquo;</TD></TR><TR><TD CLASS="quote">after u reset ur ecu, do u get the code like after hard driving.? I dont get the code till like 1/2 hour after driving.
anyway, can anyone post a picture of their plug and which wire is which, my plug isnt the right one and i cant find a picture of a pinout.</TD></TR></TABLE>
i have been driving now for 2 days about 80 miles in total and still nothing! i will take a pic of the extra harness i have and show you the pin outs tomorrow
Old Apr 11, 2007 | 05:16 PM
93CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiclxb16a &raquo;</TD></TR><TR><TD CLASS="quote">i thought the same thing but i changed my clip and it worked fine, do you have a cel for your vss?</TD></TR></TABLE>
No.. I mean either repin or cut the wire at the base of the clip, and repin or cut the signal wire at the ECU and do a direct connection. That will rule out the wiring harness.
Old Apr 15, 2007 | 07:43 PM
syler's Avatar
I hope there would be pics :D
Old Apr 15, 2007 | 07:58 PM
JDM_EK4_Coupe's Avatar
(banned)
Default Re: VSS wtf! i have no clue what to do now! (syler)
Ur plug went back. Splice and replace
Freckles
Aug 20, 2012 10:30 PM
aubreylorraine
Jun 15, 2010 04:44 PM
Mr.Death
Sep 15, 2007 09:45 PM
ek4h
Apr 15, 2007 07:49 PM
CXtypeR
Feb 12, 2007 05:57 PM
