hf to si swap
One of my friends is doing this swap, and I was going to search for info, but si and hf are not indexed since they are only two characters, so I couldn't get any info.
What I need to know is
1. will the injectors off his hf engine work for the si. I imagine they are the same size, but do they flow as well? same connections?
2. is there any wiring differences? I know the ecu plugs are the same....any extra sensor on the si that need to be hooked up? etc..
any other differences or things that need to be done other than just swapping the two motors? we have si axles....do they fit the hf hubs? If not, what is needed to swap to si hubs? Just the hubs, or other hardware.
Thanks for any help in advance
What? take the motor plug? I'm confused. Do you mean wiring harness? Do I really need an si wiring harness? I don't think my friend has that, he was just planning on using the hf harness.
Why is no one replying to this? Has no one done the swap...I'm sure many people have. Come on people, help a brother out.
from what i have read you can use the hf harness and i was going to do that because i picked up a totalled crx hf and was going to swap my frineds old si in to my sedan with that harness and trans. i hope it will work..
I will make this simple...
Swap the entire engine over (no swapping injectors/manifolds crap like that)
Pick up a SI tranny (89-91) also a flywheel and clutch assembly.
The HF wiring harness will work fine, You will have 1 extra plug left over for the small emissions control device next to the distributor.
You will need a SI ecu,
axles, you can use your STOCK HF axles. If you want to upgrade to DX/SI axles you then will need to replace your hubs.
The motor is a direct bolt in plug and play. It is a very easy swap, good luck!
I have done tons of swaps, HF's Dx's SI's to Zc's d16a6's B16's B18's whatever..
Jeff
Also, if you use the stock SI exhaust manifold or a hedder you will need to get an exhaust flange welded onto your stock HF piping.
[Modified by AbaZ, 10:20 PM 5/26/2002]
Jeff
Guest
Posts: n/a
yeppers. axles will work inside diameter for trans is all the same. hf harness should work b/c their suposed to be wired the same as the si. hf intake manifold is smaller than si. get an si one, flows much better and has a larger tbody.
other than that your all set
cool, thanks a bunch guys. Still one thing to make sure of.
We don't have the si injectors, so will his hf injectors work???
Will the hf axles hold up fine with the extra power?
thanks
thanks
EK FLY
Oct 8, 2005 07:36 AM
fullraceacura
May 24, 2005 09:49 AM
Catch 22
Jun 11, 2004 07:15 AM
