Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Adjusting clutch engagement point?
Old Mar 26, 2007 | 04:38 PM
Nighthawk R18's Avatar
Default Adjusting clutch engagement point?
anyone know how to adjust the engagement point on a base civic clutch? i think it engages to high off the floor and would like to see if i can get it to "catch" a little lower.
thanks for the input
Old Mar 26, 2007 | 06:28 PM
Default Re: Adjusting clutch engagement point? (Nighthawk R18)
wrench in hand
needs directions lol
Old Mar 26, 2007 | 07:44 PM
faster Type R's Avatar
i know...omni power makes a quick clutch thing...not sure if it will fit on the newer civics though
Old Mar 26, 2007 | 07:59 PM
Default Re: (faster Type R)
i have to buy a part? i thought it was as simple as adjusting a bolt.
Old Mar 26, 2007 | 09:31 PM
TRE_'s Avatar
Default Re: (Nighthawk R18)
The last time I did a" serious " clutch adjustment was on my 91 ZC'd CRX... then it was basically as simple as adjusting a bolt(s)... not quite the same on a newer vehicle. Why are you trying to adjust the clutch in the first place?
Old Mar 26, 2007 | 10:22 PM
Default Re: (TRE_)
it catches too high off the floor for my liking. i was just used to barely gettin the pedal off the floor and it catches when i drive my friends DC around and when i drove around my cousins old EJ. what i do sometimes in not clutch all the way down when im starting 1st gear. and so when the light turns green i just release a bit, gas a bit, and im off.
i would be nice if i got to do it, but if its too complicated and requires more than just a twist from a wrench i can live with how it is now.
dustinbs144
Feb 8, 2012 11:53 AM
JDM97dc2R
Jun 3, 2009 05:33 AM
tigueremalo
Jan 14, 2007 02:29 PM
Grease Monkey
Jul 15, 2004 05:39 PM
steve_s
Apr 1, 2003 06:43 PM
