da motor into eg
i wanna put my 93 integra motor into my eg. what parts can i use from my da for the swap? also what parts do i need to put it in the eg?
the DA motor is ls vtec if that helps any.
please help thanx!
bump
Modified by da6er at 2:22 AM 3/27/2007
please help thanx!
bumpModified by da6er at 2:22 AM 3/27/2007
what trim is ur eg? all u really need is an ex/si harness from the 92-95 civics. it'll make stuff much easier. we just did a b17 into my brother's cx using the ex/si harness was WAY easier. u'll need a t bracket from a 94+ integra and i would recommend getting a driver side mount from integra also. depending on ur tranny u'll need a hydro to cable kit if u plan on using a cable tranny.
I see that you are in california
what year is your EG?
your motor has to be the same age or newer than the car
therefore you cannot put a 93 DA motor in your 94 or 95 eg
search for california smog swap.
Why not put an OBD-I GSR motor in your EG?
iLOVEthatEMone
Jul 28, 2008 05:33 PM
