roll cage in CRX for drag racing?
Old May 24, 2002 | 08:09 PM
Reverend's Avatar
Default roll cage in CRX for drag racing?
I really never do any SCCA/Road Racing, so if I bought a roll bar/cage, then it would just be for drag. The problem is, are there any out there that are relatively light (under 100lbs)?
Where to get them? anyone have more info/pics?
Old May 24, 2002 | 08:38 PM
Bnjmn's Avatar
Default Re: roll cage in CRX for drag racing? (Reverend)
Check the rules for whatever organization you want to run. 1.75" steel tubing, the designated thickness (1/8" I think) is about 2 pounds/foot. Unless you are running a rally car, you should be able to easily make a full cage with reinforcements for well less than 50'.
If you have access to a TIG welder you can use chromoly (more $$$) and save approximately 1/3 of the weight.
Ben
Wickdkid77
Dec 16, 2009 04:21 AM
travis
Feb 14, 2004 04:20 PM
eddiecut
Dec 11, 2002 02:50 PM
blackitrspec
Oct 22, 2001 11:44 AM
