problems after intake manifold port match!!!!! help
Old Mar 26, 2007 | 03:58 PM
94hondacivicvtec's Avatar
Default problems after intake manifold port match!!!!! help
i have previously searched for the answer and found nothing. heres my delema this weekend i got a b18 throttle body and port matched my d16z6 manifold to it. after words when i started it up it idled fine. i rev-ed it up and i heard this whistling coming from the air filter. when i was putting every thing back together and i forgot to put the lower middle bolt back on. what is causing this whistling? and do i need that one lower middle bolt on the intake manifold.
Old Mar 26, 2007 | 04:01 PM
pdiggitydogg's Avatar
probably a vacuum leak...
Replace that nut you forgot to put back on and start checking for leaks.
Double check the area at the throttle body/intake manifold, specifically (since it was the area that received work). A quick way to check for leaks there, is to just place a piece of electrical tape over that junction. If its still whistling, keep looking
Old Mar 26, 2007 | 04:16 PM
Default Re: (pdiggitydogg)
the whistle sounds like a jet engine, and its pretty loud. has this happend to any one else?
Old Mar 26, 2007 | 04:52 PM
Default Re: (94hondacivicvtec)
if it is a fat vacuum leak do you think i'll be alright driving untill tomarrow?
Old Mar 26, 2007 | 04:56 PM
maybe...depends on how big of a leak
take the air filter off to see if its just that
Old Mar 26, 2007 | 05:17 PM
i took it off last night to see if some how that it was just the air filter and the sound was coming out of the intake manifold(with the air filter off). i have 15 miles to drive home from work tonight do you think that would be enugh to warp it?
Old Mar 26, 2007 | 05:37 PM
ntrider's Avatar
could the whistling be caused by the air going over the butterfly on the the TB? I dont see a problem with driving it 15 miles. You said that it idles fine and the only problem is the whislting.
Old Mar 26, 2007 | 05:38 PM
ED9man's Avatar
I had a similiar problem, I used some gasket maker **** between the TB and IM and it fixed it.
Old Mar 26, 2007 | 06:20 PM
Default Re: (ED9man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntrider &raquo;</TD></TR><TR><TD CLASS="quote">could the whistling be caused by the air going over the butterfly on the the TB? I dont see a problem with driving it 15 miles. You said that it idles fine and the only problem is the whislting.</TD></TR></TABLE>
i dont think it would be air going over the tb cause every ones car would make that sound. any one else got any ideas?
Old Mar 26, 2007 | 07:54 PM
ntrider's Avatar
I know set-ups are different but when i had a short air ram intake, from ebay with ebay filter, I had a whistling noise at a certain throttle position, was told it was from the air passing over the butterfly. Just wondering since you said that the whistling noise came from the intake manifold with the air filter off. Can you pinpoint where on the intake manifold it sounds like the whistling is coming from?
Old Mar 26, 2007 | 08:16 PM
Default Re: (ntrider)
yeah it does sound like its coming strait from the throttle body. it idles fine with no whistling but when you get it up to 1900rpm to 3000rpm it whistles. if that is it how do i stop it
Old Mar 26, 2007 | 08:20 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondacivicvtec &raquo;</TD></TR><TR><TD CLASS="quote">yeah it does sound like its coming strait from the throttle body. it idles fine with no whistling but when you get it up to 1900rpm to 3000rpm it whistles. if that is it how do i stop it</TD></TR></TABLE>
Go back to stock. Mine does the same thing.
Old Mar 26, 2007 | 08:24 PM
Default Re: (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">
Go back to stock. Mine does the same thing.</TD></TR></TABLE>
is that the only thing you can do? i just fucked my self up, spent 9 hours working on this ************, and did it on my only day off. theres got to be another way. any one please help
Old Mar 26, 2007 | 08:44 PM
i was thinking of shaving the ends of the valve, would this work or is there another way
Old Mar 26, 2007 | 09:25 PM
bump
Old Mar 26, 2007 | 09:30 PM
ridin98civic's Avatar
is that the only thing you can do? i just fucked my self up, spent 9 hours working on this ************, and did it on my only day off. theres got to be another way. any one please help</TD></TR></TABLE>
if it is just air whistling past the butterfly, there is absolutely no reason to put it back to stock, just learn to live with it.
to my understanding a large vacuum leak would cause a funny idle, but you said it idles fine.
my .02
Old Mar 26, 2007 | 09:36 PM
Default Re: (ridin98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">
my .02</TD></TR></TABLE>
i guess i'll just have to live with it. its very loud too. imight just witch the throttle bodys back. it was a good thing to do even if i didn't get a new throttle body cause my injectors,old intake manny, vac lines, tb, and inside the head were nasty caked on carbon all over it. if any one has any more ideas to keep my new tb and shut it the fuckk up, please tell me
Old Mar 26, 2007 | 09:47 PM
i would just double check all your vacuum connections to be sure.
so you cleaned out the manifold and port matched the ports to the head as well?
Old Mar 26, 2007 | 09:55 PM
yes i did. im thinking about 2 things, 1- take starting fluid and spray around the intake manifold to find vacuum leaks. 2- take old tb and see if the whistling goes away. If so i'll probley just put it back on cause this is my daily driver. THIS WHISTLING IS ****** KILLING ME!!!!!!!!!!!!! any one have any more ideas?
Old Mar 26, 2007 | 11:01 PM
put that nut that you forgot back on.
and if you decide to sell the b18 throttle body, let me know.
Old Mar 27, 2007 | 02:26 PM
ntrider's Avatar
I don't know if I got lucky or not but when I switch from ebay intake to aem intake with K&N filter I can't hear the whistling. Maybe I just don't notice it any or the exhaust hides it, so I will listen for it on my way home and let you know.
Old Mar 27, 2007 | 03:02 PM
ke98248's Avatar
The ebay filter is crap and is loud; my friend's accord when he revs it up and drives around, is quite evident that the filter is creating a lot of unnecessary noise..
My k&n filter is quiet except when I go from idle to 3-4k rev or when it's cold and i drive it.
Old Mar 27, 2007 | 04:21 PM
tx_ej8_49's Avatar
In my y8 the TPS makes a whistling sound..try putting you finger over the TPS port, see if the sounds stops and the car will die pretty quick.
Old Mar 27, 2007 | 05:31 PM
well its not a vacuum leak, i sprayed starting fluid all around it and no leak. im going to try and put the old one back on tomarrow. if that stops it then i will be selling the throttle body to ridin98civic. i will update this tomarrow.
Old Mar 27, 2007 | 10:18 PM
yes i win haha, how much were you wanting for it?
