IDLE PROBLEM AFTER ZC SWAP
Old Mar 26, 2007 | 03:48 PM
hatchbackjdm's Avatar
Default IDLE PROBLEM AFTER ZC SWAP
finished a zc swap on my friends 91 dx hatch. it will idle, but it is erratic like an iac motor. we tried using an iac from another motor we had, and it still does the same thing. any ideas?
Old Mar 26, 2007 | 05:27 PM
DoHcZC91si's Avatar
Default Re: IDLE PROBLEM AFTER ZC SWAP (hatchbackjdm)
Should do a bit of searching cuz lots of the basic problems with start-up could be fixed. As always make sure ur vacum lines are all connected correctly. Check all wiring for shorts/grounds and such. Make sure no unplugged plugs and then check for fuel/spark. Also was the check engine light on? If so check the code.
Theres lots it could be...but it's easy to fix if u know wat to look for.
DOHC zc's FTW!
Also check thezcr.com
civic4g.com
Beeean
13
Feb 18, 2012 04:56 PM
91blackcivicsi
Feb 13, 2010 04:03 PM
dubstackz
Dec 3, 2007 09:55 PM
mr_valentino20032000
Feb 2, 2005 05:17 PM
Shiro Z31-T
Dec 23, 2004 08:38 AM
