Are these good tires?
http://www.tirerack.com/tires/...ace=1
And whats this mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">NOTE: As a result of the increase in grip, PARADA and PARADA Spec-2 tires cannot be mounted on the same axle. If mixed in axle pairs on a vehicle, PARADA Spec-2 tires must be used on the rear axle with the original Parada tires used on the front axle.</TD></TR></TABLE>
No. The Yokohama Parada Spec is CRAP - meaning, its performance is woefully worse than other tires in the same price range. The best summer tire in that price range is the Kumho Ecsta SPT. Other very good tires similar in price include Yokohama's own ES100 as well as the Avon Tech M500. The Dunlop Direzza DZ101 is only slightly worse than these (still MUCH better than the Parada Spec) and is lower in price with the $50 rebate offer that expires at the end of this month.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zach1288 »</TD></TR><TR><TD CLASS="quote">And whats this mean?</TD></TR></TABLE>
It means that Yokohama makes two different tires with a similar name, and you shouldn't use the two different tires on the same axle. (You're better off not mixing those two different tires at all.)
What about these:
http://www.tirerack.com/tires/...ace=0
or these:
http://www.tirerack.com/tires/...ace=2
or these:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zach1288 »</TD></TR><TR><TD CLASS="quote">What about these:</TD></TR></TABLE>
Both are not very good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zach1288 »</TD></TR><TR><TD CLASS="quote">I found the Dunlop Direzza DZ101 in a 205/40zr16 would that be too low?</TD></TR></TABLE>
Yes, that's too small for your '97-00 Civic. For your car, you need 205/45-16 or 215/45-16.
The Kumho SPT is $74 in 205/45-16. The slightly better Avon Tech M500 is $78. These are your two "best bang for the buck" tires in your sizes.
The best deal is at Discount Tire, which has the same $74 price as the Tire Rack but offers free shipping.
So are these the correct ones, correct size and everything? I want to make sure before i order them http://www.discounttiredirect....ar=45
Modified by zach1288 at 6:20 PM 3/27/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zach1288 »</TD></TR><TR><TD CLASS="quote">So are these the correct ones, correct size and everything? I want to make sure before i order them http://www.discounttiredirect....ar=45</TD></TR></TABLE>
Yes, those are the ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">
Thank you
Thank you
SPOON_BeIgHtEeNsEe
18
Dec 7, 2003 06:44 PM
keys
Sep 25, 2001 02:21 PM
