Power loss on dyno due to check engine light?
Old May 24, 2002 | 07:57 PM
Lowez's Avatar
Default Power loss on dyno due to check engine light?
Hi...
I was wondering if the check engine light has anything to do with my power loss on the dyno. The throttle body sensor is throwing the code... Because of this I have lost 9hp and 8lb of torque at the wheels since my last dyno runs. Its a n/a type R hybrid. Could it be somethin else? Is it possible that I'm losing that much power just because of that silly sensor???
Thanks for any imput!!!!
Old May 24, 2002 | 08:08 PM
sloaccord96's Avatar
Default Re: Power loss on dyno due to check engine light? (Lowez)
i think it is it might due to unseen factors, kinda like when i have a test pipe and the CEL comes on, i lose hella torque/hp , it feels sluggish...shrug, could just be me, so i put back the stock cat , CEL disappears and it goes back to normal..
Old May 24, 2002 | 09:25 PM
Wide Open Throttle's Avatar
Hi...
fix it.
Old May 24, 2002 | 09:45 PM
mugenracer's Avatar
Default Re: Power loss on dyno due to check engine light? (Wide Open Throttle)
when my CEL light comes on the cars rev limiter cuts in at 6500rpm and vtec wont engage, so 9hp down isnt so bad unless you've over rode the CEL safety system which does both of the above.
Old May 24, 2002 | 11:06 PM
Kamin's Avatar
no sensor is silly
the tb sensor does a job
fix it.
Old May 26, 2002 | 02:47 AM
tinkerbell's Avatar
Default Re: Power loss on dyno due to check engine light? (KAMiN)
what the fleck is a throttle body sensor?
TPS????
t..
Old May 26, 2002 | 11:38 AM
Chubz's Avatar
Default Re: Power loss on dyno due to check engine light? (tinkerbell)
Is it the MAP or TPS sensor. If either are messed up you will see peformance loss.
Old May 28, 2002 | 04:06 PM
Lowez's Avatar
Default Re: Power loss on dyno due to check engine light? (SuperTech)
It's code number 7, tps.... I was making 179hp and 133LB.. Now I'm making 172hp and 125LB.....
Old May 28, 2002 | 05:47 PM
lightning's Avatar
TPS is critical in a speed-density car. Fix it first. ECU calculates air-fuel and ignition from TPS, MAP, and IAT. Any one of those fails and power will be down since ECU substitutes a default value.
lude22vti
Transmission & Drivetrain
Oct 25, 2011 01:17 PM
IntegraTypeR
Jan 2, 2009 06:21 AM
---SPEED-DEMON---
Oct 15, 2008 09:41 AM
Fabman
Sep 21, 2006 07:40 PM
1fstcorrado
Aug 9, 2005 12:09 PM
