DA Suspension Question URGENT!!!
Old Mar 26, 2007 | 03:18 PM
TsujenDB1's Avatar
Default DA Suspension Question URGENT!!!
Alright I've got the back suspension out of the back of my 90 integra 4-dr, we are trying to remove the upper strut but the bolt just turns the whole strut on the inside. How do i get the bolt on the top of the stock suspension off? we have it compressed with spring compressors btw......
Old Mar 26, 2007 | 03:28 PM
Kingfish714's Avatar
Default Re: DA Suspension Question URGENT!!! (TsujenDB1)
Use visegrip clamp to hold the inside of the strut, the chrome part. that should hold it enought to turn the nut
Old Mar 26, 2007 | 03:45 PM
IHTFP's Avatar
Default Re: DA Suspension Question URGENT!!! (Kingfish714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kingfish714 &raquo;</TD></TR><TR><TD CLASS="quote">Use visegrip clamp to hold the inside of the strut, the chrome part. that should hold it enought to turn the nut</TD></TR></TABLE>
yep.
i think i did the same thing..vise grip in one hand, wrench in the other
edit: nevermind..i remember using an allen wrench now...silly me
Modified by IHTFP at 3:51 AM 3/27/2007
Old Mar 26, 2007 | 05:35 PM
schardbody's Avatar
DO NOT DO THAT UNLESS YOU ARE REPLACING THE STRUT.
the proper way is to use the 5mm allen wrench in conjuntion with the 14mm wrench to loosen it.
if you put vise grips on the shaft of the strut you will put marks on it, and when them marks pass through the seal in the damper body it will damage the seal, therefore, you will need new struts.
Old Mar 26, 2007 | 07:26 PM
r3v da t3g's Avatar
Default Re: (schardbody)
I would just simply place it on the ground, slip in a 14mm wrench, then allen wrench. Spin it to where the ground stops the allen wrnech from moving and start unscrewing until it pops or just loosen it and then compress blah blah blah
Old Mar 26, 2007 | 10:39 PM
92integraVTECgsr's Avatar
Default Re: (r3v da t3g)
u have to use the allen wrench method.. get some liquid wrench on the bolt, and long allen key that is strong or put a bar on it and then use the wrench.
Old Mar 26, 2007 | 10:44 PM
blackKready's Avatar
Default Re: (92integraVTECgsr)
from my experience , depending on your location , and age of vehicle , your not getting them off without heat. youl either break the stud off with nut still on it , or strip the allan hole.
Old Mar 26, 2007 | 10:59 PM
TsujenDB1's Avatar
bam! suspensions done, yeah had to use the allen wrench, ill post some pics up tomorrow.
Old Mar 27, 2007 | 09:12 AM
Default Re: (TsujenDB1)
atta fire dude , nice going , your lucky , they can be real ******** to get off without ruining the strut.
reeder321
Nov 26, 2008 06:05 PM
komat
15
Dec 20, 2004 05:18 PM
O RLY
Sep 28, 2004 10:09 AM
Nocturnal
Nov 26, 2003 04:03 PM
RCautoworks
Jun 20, 2003 07:27 PM
