ITR oil pan?
Old Mar 26, 2007 | 02:18 PM
Chicano's Avatar
Default ITR oil pan?
Does the ITR oil pan have a p30 on it or no? can a gsr oil pan fit on a type r block? Trying to figure out if this motor is a jdm r or a poor r.
Has the p30 head
type r manifold
but a p72 oil pan
Any other distinct ways of telling appart the blocks?
Stamped B18C
Old Mar 26, 2007 | 02:46 PM
hayabusa160's Avatar
Default Re: ITR oil pan? (Chicano)
itr motor used a p72 oil pan. you cant put the p30 pan on it
Old Mar 26, 2007 | 02:48 PM
Chicano's Avatar
Default Re: ITR oil pan? (hayabusa160)
Thanks bro.
Old Mar 26, 2007 | 06:01 PM
RIPJemal
Guest
Posts: n/a
an b18c is a jdm gsr
Old Mar 26, 2007 | 07:03 PM
highroller54's Avatar
Default Re: ITR oil pan? (civicfla2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicfla2 &raquo;</TD></TR><TR><TD CLASS="quote">an b18c is a jdm gsr</TD></TR></TABLE>
a b18c is also a jdm integra type r.
Old Mar 26, 2007 | 07:06 PM
R you serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chicano &raquo;</TD></TR><TR><TD CLASS="quote">
sweet pic
Old Mar 26, 2007 | 07:12 PM
neo_'s Avatar
The GSR and the Type R use identical oil pans. The bare GSR and Type R blocks are identical anyway, go check the stamp on the other side of the block, both the Type R and GSR blocks will say P72.
Old Mar 28, 2007 | 01:03 PM
b18psi's Avatar
So the LS b18b oil pan is different?
neo_'s Avatar
Default Re: (b18psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18psi &raquo;</TD></TR><TR><TD CLASS="quote">So the LS b18b oil pan is different?</TD></TR></TABLE>Yes
Old Mar 29, 2007 | 10:02 AM
len's Avatar
len
From my experience, you can use any pan you want so as long as you have matching Oil Pickup and Dipstick.
Old Mar 29, 2007 | 11:41 AM
doood's Avatar
been there done that
Default Re: ITR oil pan? (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">From my experience, you can use any pan you want so as long as you have matching Oil Pickup and Dipstick.</TD></TR></TABLE>
but b18c blocks have the girdle and a deeper pan to compensate. ls/b16's dont use a girdle and would have a shallower pan.
Old Mar 29, 2007 | 12:11 PM
b18psi's Avatar
I was wondering if you guys could help me out since the OP doesn't seem to be following the thread anymore.
I have a b18b block and I am trying to get the oil pan, pickup, and baffle pan to work. I have a b18c1 oil pan, baffle and oil pickup but the baffle pan won't bolt up to my b18b block (LS/VTEC). So I am wanting to use an LS baffle tray with a b18c1 oil pickup and oil pan. Will this work?
Old Mar 29, 2007 | 12:24 PM
len's Avatar
len
Default Re: ITR oil pan? (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">but b18c blocks have the girdle and a deeper pan to compensate. ls/b16's dont use a girdle and would have a shallower pan.</TD></TR></TABLE>
Correct and Correct. The Oil Pickup on the B18C blocks sit lower because of the deeper pan. The Oil Pickup on the LS/B16 sit higher because of the shallow pan. We ran into an issue with a B18C1 engine that we did not have an available P72 oil pan for. We had an extra LS motor laying around. At first when removed it would not clear the Oil Pickup. Instead of bending the Oil Pickup, we removed the oil pick up off of the LS engine and installed it on the B18C1 engine. It is a real tight fit and the Oil Pickup barely portrudes out of the girdle. I wouldn't recommend it as a permanent fix, just a bandaid fix until you can get the proper oil pan which we did a week or so afterwards.
BoostnEK6206
Mar 23, 2008 02:51 PM
Flamenco-T
Jun 7, 2006 01:45 PM
MrHeeltoe
Aug 26, 2004 09:07 AM
JurakS
May 31, 2003 08:50 PM
lilxvtecxpwr
Feb 19, 2003 05:24 AM
