FS: Male Header Pins to chip your ECU for s300
I got a batch of these male pins that are required for preparing your ECU for Hondata s300.. Each strip has 50 pins, enough to cover the 28 pin interface and 4 pin data port..
I'm looking to get $1.50 shipped for each strip. Or I can offer a discount if you buy 2 or more for chipping your ECU or your friends..
I will post up pics later..
Modified by 92HB_HB at 8:53 AM 4/3/2007
I need a pic of the pin strip.Do they plug into the 28 pin female?Or will the existing socket have to be removed?Need more detail on how these work.THANKS
you'll have to de-solder the rom socket in order for it to work properly w/ the s300 board..
once' that's done, all you have to do is solder in the new male pins and insert the s300 board..
American.Graffiti
Sep 22, 2012 01:59 PM
92HB_HB
Apr 9, 2007 07:28 PM
