Floaties in Brake Fluid
Old May 24, 2002 | 07:09 PM
robbin's Avatar
Default Floaties in Brake Fluid
I just bled the brake fluid from the integra with Valvoline Synpower. Everything went pretty well and my pedal in definitely firmer (good news since this was my first bleed) but when I added the new fluid into the reservoir it stirred up some white stuff. It wasn't solid, more gelatenous (sp?). The fluid that was in there was pretty old I think so I tried to flush it out fairly well; I used over half the bottle of valvoline. Can anyone tell me what the white stuff was and if it's bad or not?
Thanks
-Chris
Old May 24, 2002 | 07:12 PM
HOOKUPS-PRO-CRX's Avatar
Default Re: Floaties in Brake Fluid (robbin)
that is just a bit of water accumilation
Old May 24, 2002 | 07:18 PM
robbin's Avatar
Default Re: Floaties in Brake Fluid (HOOKUPS-PRO-CRX)
Oh okay, do I need to do anything about it? Should I flush it some more?
Thanks for the quick response btw.
-Chris
Old May 24, 2002 | 09:27 PM
Wide Open Throttle's Avatar
yes, get all the water out of your brake lines. if you do not, it will boil as soon as you do any hard braking and you will have air in your brake lines. air = mushy pedal.
Old May 24, 2002 | 09:41 PM
AmginE's Avatar
Default Re: Floaties in Brake Fluid (Wide Open Throttle)
air = mushy pedal = long time use problems = master brake cylinder breaks. (mine did)
Old May 27, 2002 | 09:27 AM
Default Re: Floaties in Brake Fluid (Teken)
damn that ish was deep. anyways yes have the entire system bled. also check the cap on the reservior to make sure that it is not leaking h2o inot the fluid.
strider2
Honda CR-V & Element
May 11, 2018 11:51 AM
StolenTeg
Sep 5, 2006 05:05 PM
mrpeabody
Mar 19, 2004 06:50 AM
Understeer
Nov 30, 2003 10:28 AM
gingboy
Jul 11, 2001 05:01 PM
