dohc zc to d15b7 now wont run
Old Mar 26, 2007 | 11:50 AM
etant333's Avatar
Default HELP!!! dohc zc to d15b7 now wont run
Ok i know i shouldnt be going from zc to d15b7 but i need good gas mileage and im broke. I put the motor in and hook everything up staying obd0. i used the d15b7 intake mani and fuel rail with the injectors out of my zc. <U>now the car will crank and stumble right when u turn the key and thats it. If you completely cover the throttle body the car will start and run kinda</U>. It seems like there is not enough fuel for the amount of air that is supplied or somthing like that. The o2 sensor is also not hooked up if that makes a difference.
Please help
Modified by etant333 at 7:11 PM 3/26/2007
Modified by etant333 at 7:12 PM 3/26/2007
Old Mar 26, 2007 | 12:14 PM
dr_latino999's Avatar
Default Re: dohc zc to d15b7 now wont run (etant333)
Are you using the D15B7 distributor with an OBD-0 ECU?
Old Mar 26, 2007 | 01:41 PM
ef_zcvtec's Avatar
Default Re: dohc zc to d15b7 now wont run (dr_latino999)
if you completly covered the TB, and the car still rauns, you have an air leak....
Old Mar 26, 2007 | 02:07 PM
19992civichatch's Avatar
bump
Old Mar 26, 2007 | 02:41 PM
etant333's Avatar
well not completely covered but very restricted and it barely stays running for a few seconds but better than just open.
yes im running d15by dizzy on obd0 ecu i rewired it. how do i tell the diff between obd0 and 1 injetors
Old Mar 26, 2007 | 02:42 PM
etant333's Avatar
also it ran when i sprayed ether in the intake as i started it. is there any way the fuel could be bad or that for some reason the injectors are not gettin fuel through that rail?
Old Mar 26, 2007 | 02:49 PM
Default Re: (etant333)
You CAN not use the D15B7 distributor with an OBD-0 ECU, the signals are incompatible.
Old Mar 26, 2007 | 02:53 PM
etant333's Avatar
i cant use any obd1 ecu? i thought i could
Old Mar 26, 2007 | 05:10 PM
etant333's Avatar
bump
Old Mar 27, 2007 | 02:41 PM
etant333's Avatar
anyone else run into this?
JDMefHATCH7
16
Oct 30, 2009 07:06 PM
ZCPoweredHatch
Nov 7, 2006 11:52 AM
drewboy
May 8, 2005 05:24 AM
Jmorin
Feb 10, 2004 09:38 AM
clsmooth
Dec 30, 2003 03:44 PM
