passing e-test without cat?
Old Mar 26, 2007 | 11:12 AM
civic_66's Avatar
Default passing e-test without cat?
is it possible?
Old Mar 26, 2007 | 11:18 AM
Kingfish714's Avatar
Default Re: passing e-test without cat? (civic_66)
Impossible, unless you do it illegally.
You will fail for excess Carbon Monoxides, Hydro Carbons, & Oxides of Nitrogen- Emissions Test plus don't forget about the visual.
Old Mar 26, 2007 | 11:24 AM
Relic1's Avatar
I see Mississauga ON as a location, canada emissions testing is not near as bad as Cali's.
it is possible but not easy. Takes a lot of messing with the tuning and getting things perfect for the test. Not worth it IMO, just pick up a cat and drop it in there for a day.
Old Mar 26, 2007 | 11:38 AM
civic_66's Avatar
Default Re: (Relic1)
alright thanks a lot guys. Another quick question. For the safety i got ITR rears in my car. as you all kno they dont fit 100% and arnt bolted down. Will this cause the car to fail?
Old Mar 26, 2007 | 11:45 AM
Relic1's Avatar
Default Re: (civic_66)
ITR rear seats?
They are worried about how the car runs not how safe it is.
secure the seats before you have to slam on the brakes and end up with them at the back of your head.
Old Mar 26, 2007 | 11:46 AM
blaze_125's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_66 &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks a lot guys. Another quick question. For the safety i got ITR rears in my car. as you all kno they dont fit 100% and arnt bolted down. Will this cause the car to fail?</TD></TR></TABLE>
I'm new to this Honda stuff so my answer might not be relevant.
When you say ITR rears, I assume you're talking about suspension components. If your not, disregard my answer.
If there is exessive play when the tech starts pulling and pushing the wheels... it will fail.
Old Mar 26, 2007 | 11:47 AM
civic_66's Avatar
lol na man the back rest are in snug they fit perfect. But the part of the seat you sit on its basically just placed there with the belts through it. Its not like there gunna sit in my back seat right. So it should be fine?
Old Mar 26, 2007 | 12:22 PM
krazyhmongboi's Avatar
my brother's car passed emission with this turbo integra without a cat
Old Mar 26, 2007 | 12:26 PM
civic_66's Avatar
Default Re: (krazyhmongboi)
oh really!!? must run clean...wow
Old Mar 26, 2007 | 12:28 PM
Chicano's Avatar
I barely failed HC idle, passed everything else with 93 civic si, 3" exhaust, stock header (no cat) and a b18c r motor, I put a gallon of ethanol in on a half of tank of gas, ran it for an hour and went to do the test. Prob could of passed with a slight adjustment, but I ended up licensing it in a diff city. May work for you tho
Old Mar 26, 2007 | 12:32 PM
yea the guy at the place was just like..o ur car runs really good..and revved it up at like 2k rpm for a while and then said it passed while the other lady tested the exhaust..i hope i pass
Old Mar 26, 2007 | 03:36 PM
wrx'n you's Avatar
u will fail. if ur car is obd2 and they hook up the computer to ur car and u have no CELs u will pass that part. but u will fail cause they do a visual inspection on ur car. and since ur car comes with a cat from the factory, and u dont have one, u will fail.
soclean1k_JDM
Welding / Fabrication
Sep 10, 2008 01:04 PM
orangeracer
Aug 13, 2007 08:22 PM
blks2k3
Nov 11, 2005 04:57 PM
Tommy1223
May 30, 2005 10:12 AM
Boring
Jan 1, 2005 04:31 PM
