What does DC, DA, etc. mean?
well... i don't know all of them shortend meanings but DA is reference to the 93 and earlier integras. DC is the newer integras and i think DC5 is the type r... or maybe it's the rsx... i dunno, someone else around here prolly has more accurate info... the EG and EK and EP are all civics tho.
im probably wrong, but for what i know, DA is the 90 - 93 integras DC2 are the 94 throught 2001 integras DC5 are the RSX, EP3 are the 2001 and up civics,EF9 are the 89 through 91 hatchy's, EG6 are the 92-95 civic hatchbacks, EK9 are the 96 - 2000 hathbacks thats about all i know
DA9 are 90-93 RS, LS, GS hatchbacks
DB1 are 90-93 RS, LS, GS 4dr
DB2 are 92-93 GSR
DC2 are only GSRs and Type Rs
DC4 are all other 94-01 hatchback integra
DB7 are all 94-01 4dr integra
DC5 is RSX, not sure of the specifics on this one.
DB2 are 92-93 GSR
Ok, someone correct me if I'm wrong, but these are the chasis code that you can simply find within the numbers in your VIN. As stated before, EF's, EG's, EK's, EP's are all Civics, and the DA's and DC's are Integra's and RSX's. DA= 90-93, DC2's (LS), DC4's (GSR, Type-R) are the 94-01 Integra (DB8's are the 94-01 4dr), and DC5 is the RSX. I hope I'm right, feel free to correct me if I'm not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixfiveoh »</TD></TR><TR><TD CLASS="quote">DA9 are 90-93 RS, LS, GS hatchbacks
DB2 are 92-93 GSR
DC5 is RSX, not sure of the specifics on this one.</TD></TR></TABLE>
correct except db7 is RS, LS, GS 4 drs and db8 is GS-R 4 dr, or the other way around...
DB2 are 92-93 GSR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1998b18c1 »</TD></TR><TR><TD CLASS="quote">chassis codes dc2 gsr, dc3 itr, dc5 rsx.
where the expletive you get dc3? lol
</TD></TR></TABLE>where the expletive you get dc3? lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_2k5 »</TD></TR><TR><TD CLASS="quote">
correct except db7 is RS, LS, GS 4 drs and db8 is GS-R 4 dr, or the other way around...</TD></TR></TABLE>
ah yeah, forgot about the 4dr gsr
where the expletive you get dc3? lol</TD></TR></TABLE>
lol i was thinking that too
i pulled it up on the acura interactive network--1998 vin identification showed a 98 type r as having a dc3 chassis code might be a typo--bcuz when i looked at the 97 type r it had dc2 and for 2k n 2k1 it had dc2 as well--will have to research.
i pulled it up on the acura interactive network--1998 vin identification showed a 98 type r as having a dc3 chassis code might be a typo--bcuz when i looked at the 97 type r it had dc2 and for 2k n 2k1 it had dc2 as well--will have to research.</TD></TR></TABLE>
never heard of it, but i guess it could be possible but probably not in the U.S. Might be similar to japan and other countries having b18c3 and b18c4's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixfiveoh »</TD></TR><TR><TD CLASS="quote">DA9 are 90-93 RS, LS, GS fastbacks
DB2 are 92-93 GSR
DC2 94-01 are only GSRs and Type Rs
DC4 are all other 94-01 fastback integra
DB8 94-01 4dr gsr
DA6 jdm xsi
DA9 usdm 90-93 integras
corrected!
Modified by CW_98gsr at 1:26 PM 3/26/2007
DB2 are 92-93 GSR
DB8 94-01 4dr gsr
DA6 jdm xsi
corrected!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr »</TD></TR><TR><TD CLASS="quote">
corrected!
Wrong, DA6 is a JDM Xsi, DA9 is USDM.
corrected!
Wrong, DA6 is a JDM Xsi, DA9 is USDM.</TD></TR></TABLE>
i though i put it there
EDIT: your right, corrected again
But what's an even more interesting question is,does anyone know what chassis code is for 1st gen. integra??
da6 - 2nd gen integra jdm, xsi
da9 - 90-93 usdm integra
dc2 - 94-97 integra
dc4 - 98-01 integra
dc5 - rsx
as far as i know. i'm trying 2 learn all the motors.
i believe:
d16 - 1st gen teg.
b18a - da motor ls
b17 - 1st gen gsr 92-93
b18b - dc2 motor
b18c1,2,3,4, - gsr motors but i don't know all the regions
b18c5 - usdm type r
b18c6 - jdm type r
b18c7 - dtm type r (europe)
k20b - rsx
k20a is base model (ep3) rite??
dc2 - 94-97 integra
dc4 - 98-01 integra
dc5 - rsx
i believe:
d16 - 1st gen teg.
b18a - da motor ls
b18b - dc2 motor
b18c5 - usdm type r
b18c6 - jdm type r
k20b - rsx
DC3? when you thought you've seen it all...
to be genaral
DA=older teg before the circular headlights
DC=circular headlights
DC5=RSX
there is alot more to it then that but i figured if you asked then that would be enough info for you for now... no need to go further
to be genaral
DC5=RSX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DevilSephiroth »</TD></TR><TR><TD CLASS="quote">But what's an even more interesting question is,does anyone know what chassis code is for 1st gen. integra??
dc2 - 94-97 integra
dc4 - 98-01 integra
dc5 - rsx
i believe:
d16 - 1st gen teg......someone correct me, dont 1st gen come with ZC's? 1.6 dohc
b18a - da motor ls
b17 - 2st gen gsr 92-93
b18b - dc2 motor......nope that is the dc4
b18c1,2,3,4, - gsr motors but i don't know all the regions....too complicated (search)
b18c5 - usdm type r
b18c6 - jdm type r wrong, b18c can be either jdm gsr or jdm ITR
k20A2 - rsx type s
k20a is base model (ep3) rite?? nope, that sir is the ITR k20a3 is ep3 and base model rsx
and the new si is i believe K20Zsomething...someone correct me on this one
fixed
dc2 - 94-97 integra
dc4 - 98-01 integra
dc5 - rsx
i believe:
b18a - da motor ls
b18c5 - usdm type r
k20A2 - rsx type s
fixed
i don't think there has been one entirely correct post in this thread. as far as the 3rd gen integras go, a dc2 is a vtec coupe (gsr, type r), a dc4 is a non vtec coupe (ls, rs, gs), a db8 is a vtec sedan (gsr) and a db7 is a non vtec sedan (ls, rs, gs). that's all i'm really 100% sure of and don't want to be another idiot posting up incorrect information.
fixed</TD></TR></TABLE>
thanks for making me feel better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clover99b18c1 »</TD></TR><TR><TD CLASS="quote">i don't think there has been one entirely correct post in this thread. as far as the 3rd gen integras go, a dc2 is a vtec coupe, a dc4 is a non vtec coupe, a db8 is a vtec sedan and a db7 is a non vtec sedan. that's all i'm really 100% sure of and don't want to be another idiot posting up incorrect information.</TD></TR></TABLE>
and thanks to you too. a bunch of morons arguing over chassis codes and not one of them can get one right. THANK YOU THANK YOU THANK YOU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedNslowLS »</TD></TR><TR><TD CLASS="quote">
and thanks to you too. a bunch of morons arguing over chassis codes and not one of them can get one right. THANK YOU THANK YOU THANK YOU</TD></TR></TABLE>
it's be funny to run into somebody who's just blabbing incorrect facts sounding all confident that they know their **** and all you can do is shake your head in disappointment.
