Air Condition problem with 2000 accord ex 4cy
Old Mar 26, 2007 | 09:20 AM
debigram123's Avatar
Default Air Condition problem with 2000 accord ex 4cy
My airconditioning only blows cold air while the car is accelerating. This just started a couple of days ago. When you are idoling it only blows hot air? It has not been overheating at all.
Old Mar 26, 2007 | 09:27 AM
gulfview's Avatar
Default Re: Air Condition problem with 2000 accord ex 4cy (debigram123)
Are the belts tight enough?
Old Mar 26, 2007 | 09:32 AM
YeuEmMaiMai's Avatar
it's either
1. door stuck partially open
2. low charge
3. loose belt (you would hear it squealing)
it might be but not likely
4. blockage in system
5. faulty compressor
6. bad clutch that is slipping on compressor (u would smell something burning)
Old Mar 26, 2007 | 09:36 AM
Default Re: Air Condition problem with 2000 accord ex 4cy (gulfview)
Not really sure about that. I am suppose to have someone check it out for me this evening. Thought it might just need added coolant but I was told I could do more harm that good if that wasn't the problem. I have not heard any squeaking from the belts.
Old Mar 26, 2007 | 09:38 AM
Default Re: Air Condition problem with 2000 accord ex 4cy (YeuEmMaiMai)
What does a blockage in the system indicate?
Old Mar 26, 2007 | 09:46 AM
blockage in the system usually indicates compressor failure if the system is not leaking.
you can usually know this by taking pressure readings on high and low side and determine what is going on based upon the readings.
Old Mar 26, 2007 | 02:19 PM
jdmarzan671's Avatar
Check your compressor for a leak.
purplemoon16
Apr 30, 2013 03:39 PM
texcon
May 29, 2012 09:14 AM
kelsarr
Jun 21, 2010 05:13 PM
rayho
Aug 14, 2006 08:52 AM
pare618
Jul 17, 2006 09:02 AM
