rear disc swap help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_kevin_ca »</TD></TR><TR><TD CLASS="quote">does anybody know if the DA swap fit on EGs at all? thx HT!</TD></TR></TABLE>
Yes the whole trailing arm will fit just fine. You will probably want to retain your other control arms (LCA, UCA & compensator arms) though just in case. At least make sure they are the same length before you put them on...
Keep in mind that this is the only trailing arm with the larger bushing. If you ever want to replace that bushing, you will have remember to get the one for the 90-93 Integra...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">
Keep in mind that this is the only trailing arm with the larger bushing. If you ever want to replace that bushing, you will have remember to get the one for the 90-93 Integra...</TD></TR></TABLE>
ok, so i gotta use the LCAS from my civic? whats UCA and conpensator arms??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_kevin_ca »</TD></TR><TR><TD CLASS="quote">oh, and what kind of cable do i need?? the DA brake cable or EG?</TD></TR></TABLE>
I know the DC cables fit on my EG hatchback with 1 creative screw on the drivers side cable). If your EG is a hatchback, and you want a "perfect" fit, get the 92-95 Si cables.
The EG sedan & coupe have a longer wheelbase though, so you might need something else. I don't know about the DA cables though sorry...
yeah, i have a sedan, but i searched and saw only 91-2001 integra will fit, but what if the car is a 90 integra? i am confused.. and anybody could give me a list of all the parts i need for this swap plz?!
</TD></TR></TABLE>yeah, i have a sedan, but i searched and saw only 91-2001 integra will fit, but what if the car is a 90 integra? i am confused.. and anybody could give me a list of all the parts i need for this swap plz?!
yeah, i have a sedan, but i searched and saw only 91-2001 integra will fit, but what if the car is a 90 integra? i am confused.. and anybody could give me a list of all the parts i need for this swap plz?!</TD></TR></TABLE>
I think one of the 92-95 sedans must have come with disc brakes. Just find the right model & buy new cables. Then you know it will fit perfectly...
If you don't want to do that, you can try some 94-01 Integra sedan ones. Either way, any hatchback model cables will most likely be too short...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_kevin_ca »</TD></TR><TR><TD CLASS="quote">its really hard to find any hondas in the junk yard from where i live...
I meant buy NEW cables from an online dealer like HondaPartsDeals.com (they have a H-T coupon code too for $10 off). They aren't that expensive.
</TD></TR></TABLE>I meant buy NEW cables from an online dealer like HondaPartsDeals.com (they have a H-T coupon code too for $10 off). They aren't that expensive.
